Hi Bob,
Did everything good come out Bell Labs?
Q enhancement seems to get a bit worse with higher bandwidth op amps like the 1468.
Higher BW but maybe not high enough to combat the problem. I did find if I use a op amp with higher bandwidth than the 1468 in the high pass section I can go with out lead compensation. With the Q enhancement under control I find I can use a lot more decoupling between the multiplier and SVO. The control voltage stays in a tighter range and of course the distortion and noise is lower with the added decoupling.
I though you put resistors at the inputs of both integrators. I'll have to look again.
Yes you have 220 ohm resistors at the integrator inputs before the cap and tuning resistor.
Is that for a different reason?
Do you mean like this Widlar?
"digital? every idiot can count to one" -- Bob Widlar - Clifford's soup
The 220 ohm resistors were just insurance against op amp instability.
Yes, that is Bob Widlar! You gotta love that photo.
Bob
I could have sworn I put in a tweak for Q enhancement on the 200kHz range of my THD analyzer, but I just went back and looked at the old schematic and could not find it.
Isn't it there in table 2. p.58 Part 3?
Best wishes
David
you mentioned the ability to sweep...
I want a simple tunable option, like the Tek 505, not very complex, just a dual track potentiometer.
I do not need an Audio Precision style oscillator with fast computer frequency control for production line tests, impressive as they are.
I mentioned earlier we have to sort out what is theory from personal opinion.
Well, yes that's why I wrote "Presumably".
Glen made it clear that this was his idea of the cause of the problem. He asserted that the quadrature relationship of the SVF is never quite exactly 90 degrees and that the added phase shift from lower GBP op amps cured this problem
I need to re-read exactly what he wrote. Do you have the link or a copy, not sure I can find it.
There is a well documented phenomena call Q enhancement. Q enhancement is cause from finite bandwidth of the amplifier.
I understand there are effects from the finite bandwidth of the amp. I am not sure if this actually contradicts what GK wrote, maybe just another way to look at it, but perhaps I remember his view incorrectly.
a very small capacitor 3-7pF across the resistor...
This approximates Bode Maximum Feedback, which I have advocated over in the Solid State forum, so seems reasonable to me.
Here is quote from Electronic Filter design Handbook, Arthur B. Williams and Fred J. Taylor.
"Another serious limitation occurs because of finite amplifier bandwidth. Thomas (see Biblio...
What is the Thomas reference itself?
...if you depart from unity and add gain to the input it causes an imbalance ... and the amplitude at the BP and LP output will be unbalanced.
Yes, I understand the effect on the relative quadrature outputs, and since I want to try an (enhanced) Sum of Squares leveler I want them equal.
AFAIK Bruce Hofer used gain simply to eliminate an op-amp.
That is not a major concern for my requirements, just wanted to check that there was not some other point I had missed.
Try it in spice... By the way the Q enhancement effect doesn't show up in spice like it does with a real model. No help there.
I don't need to try that bit in Spice but I do realize that the macro-models are often pretty bad.
There was an excellent discussion by someone of attempts to model op-amps accurately that dissected many model problems, failures by the manufactures to address the problems, denial there was any problem, etc etc.
Wish I could remember where I saw it, sound familiar to anyone?
Best wishes
David
Here is something for everyone to ponder.
The gain at resonance of an SVF, SVO is some 60dB or more depending on the amplifiers used.
I've measure this in an undamped SVF. It correspond to an SVF in spice.
As you all know the bandwidth of an op amp depends on the closed loop gain of the amplifier according to GBP. So what is the bandwidth of an undamped SVF if the gain at resonance is 60dB and GBP is 24MHz?
Another half remembered article was a measurement of the decay of an SVO with only the outer loop closed.
The author attributed essentially all the losses to ESR in the capacitors and calculated the putative value.
I was not convinced so I didn't bookmark it, now I'd like to re-examine it if anyone knows the reference.
Best wishes
David
Best wishes
David
I had looked there and did not see it.
Bob
Bob
There is one 68 and 180 ohm resistor mentioned on the table.
Are these for the integrator caps?
Best wishes
David
What about the resistors? Aren't they lossy.
Dave you can close the K+ loop without an amplifier but you will have to add some damping somewhere and balance it with the K+ feedback. Otherwise the settling will be slow.
I eliminated one op amp by combining part of the multiplier with the HP section amplifier.
But I already had an inverted signal from the Mdac I/V convertor.
There is one 68 and 180 ohm resistor mentioned on the table...
There are actually two 68 ohm resistors, the column header is (KM,LN) to indicate both the KM and the LN connections.
These are the ones in the oscillator, their effect on Q-enhancement is mentioned in p.57 second column.
Sorry, I don't follow the reference, what is the K+ ?
Best wishes
David
Best wishes
David
It been more than 25 years since I read though the article. You seem to have it fresh in your mind.
The k- and K+ are the loop gains. oscillation occurs when the gain is at unity: when
K- * K+ = 1.
Here is an analysis for Wien.
VK-1 Audio Oscillator
...You seem to have it fresh in your mind.
I have a copy from Bob's website, just checked that.
K- * K+ = 1.
OK+, just needed to know your notation, I will think a bit more.
Also about your comment on the losses in the resistors, I have previously pondered this issue in feedback amplifiers.
I rechecked GK website and still can't find the comments about Gain-Bandwidth problems, probably deleted.
Best wishes
David
I know Bruce encountered the Q enhancement problem because the compensation technique was used in the Sys One oscillator and I believe the Tek 505.
It is used in the Tek 505, thanks for the reminder.
Now I think of it, the optimal technique should be to use both Bruce's and Bob's tweaks.
Capacitor across the inverter feedback resistor in combination with resistors in series with the integrator capacitors.
My first intuition is that the time constants should match, to keep the loop "flat" (i.e. same level at every op-amp)
One extra capacitor seems a small price, I wonder how far the loop frequency can be pushed with, say, AD797s?
Best wishes
David
Best wishes
David
Hi Dave,
Thanks ever so much for finding this and pointing it out.
Bob
Best wishes
David
Keep in mind that input resistance of the op amp loads the integrator cap.
The LT1468 has a relatively high input resistance which is one of the reasons I choose it for my SVO.
The search is over:
http://www.janascard.cz/PDF/An ultra low distortion oscillator with THD below -140 dB.pdf
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Jan
Jan
Thanks, Jan. Excellent article and superb performance.
I am especially thankful that the paid attention to, and addressed, oscillator noise, which I think would be a good area of additional focus on this thread.
However, note that it is a single-frequency oscillator with a tight agc trim. This greatly reduces the needed authority of the agc circuit, reducing both its noise and distortion contribution.
BTW, I heard that TI is dropping the LME IC line, or at least a very large part of it. Anyone know if there is any truth to that?
Bob
Bob
Yes. Most of the line is dropped with only a few remaining. TI said they would supply for one year and then poof.
The search is over:
I am reasonably sure this circuit was discussed, and dismissed, much earlier in the thread.
When I read the thread recently, in an effort to catch up, I found some trials of what I think was this circuit.
Unfortunately the link to the circuit was to a journal article and now dead, but seemed to be the same circuit as your link.
As Bob says, distortion can be reduced if you reduce control authority, and this circuit achieves it's low distortion with very low control authority.
The consensus of the discussion was that the control authority was sufficiently low as to make the circuit very "tweeky", very sensitive to component tolerances, mismatch etc.
This makes sense, it's a very conventional circuit, to make it perform much better than any other Wien B. will require heavy trade-offs.
Thanks.
Happy to be helpful, it's made me really think about this issue.
Yes I think some stuff from GK's site has be taken down.
Now that I really think about it, I notice that GK's oscillator has the hi-frequency tweek capacitor across the inverter local feedback resistor.
This will produce exactly the opposite effect to what is done in the Tek 505 by Bruce.
Very odd, could this be the reason for GK's problems?
I checked, and both Bob and Bruce's tweeks do indeed have about the same time constant.
They both use the same variety of op-amp, so that reinforces my idea that the inverter and integrator TCs should match.
Also the Renardson SV oscillator has a 505 style capacitor and similar TC but the amps are different so not directly comparable
Best wishes
David
- Design & Build
- Equipment & Tools
- Low-distortion Audio-range Oscillator
