Cheers for this Prasi,
A bit of a newbie to this area, so looking for feedback on post #1537 above
Planning on using:
584-LT4320IN8-1#PBF
757-TPH1R306PL1LQ mosfets if singles pcb
78-SQJB00EP-T1_GE3 mosfets if doubles pcb
https://www.mouser.com/ProductDetail/80-C0805C105J3RACTU
80-C0805C105J3RACTU resistors
327-VFR1105WTR LEDs, if I put them in
Any thoughts or opinions?
Cheers
Planning on using:
584-LT4320IN8-1#PBF
Cheers
Planning on using:
584-LT4320IN8-1#PBF this is ok.
757-TPH1R306PL1LQ mosfets if singles pcb - this is ok, but see if you can find something with lower Qg. Rdson of 3-5mOhm or 7 mOhm is also ok
78-SQJB00EP-T1_GE3 mosfets if doubles pcb- not compatible with my SMD pcbs shipped to you.
https://www.mouser.com/ProductDetail/80-C0805C105J3RACTU this is ok. but see if you can find 1210 size. you can go up in value also say 4.7uF
80-C0805C105J3RACTU resistors - this is the same cap.
327-VFR1105WTR LEDs, if I put them in - ok. see if you can find 1210 size.
LED resistor should also be 1210 size..
- Group Buys
- LT4320 based active rectifier
