got it! seems ok. both fst´s @33cm
Sorry don´t have time to put any cat gifs
rear needs to be dampened, just lil´bit "horny, spiking beaming" how do i say it.
atleast it´s easy with this construction.
and never ever use these in ob, soldered for sure.
Excellent, congrats! B&W looks to be usable as nude dipole crossed LR4 or steeper at 300 and 3000Hz.
Now some relaxed listening and little by little some more experimenting with different xo F and slopes. The tweeter is horn type, there is some challenge to make it smoothly match this B&W. And I mean smooth not only in direct sound but more importantly off-axis and power response+decay wise.
daum dat GBP exhange rate could be little bit lower. double or triple 18"? where to put the third?Problems with midrange was clearly my room, turn speakers around and now listening some might say too close but i prefer early reflections than 0,7.
i could put channels to supermodule which means same dsp setups between channels right away.
0,7 setup needs to be little different
it´s the room and i know it
crossing 2.5k helped a lot.
new speaker placement is bit too bassy.
playing louder to BMS there goes around 35volts rms
aiming the right one, this time tweeter mount without horn and cover
green is with horn and cover
Dauumn is it 2am allready!!
started working, came to computer and Naula the cat sat on my lap immediately, lost some working time, njaah, it happens.
But first Tri-Pred is ready! i even paint it right away.
tomorrow is gonna be laugh, without jig is bit PIA to get even 80% similar stuff.
tweeter response looks really bad atleast. i dont know whats happening. could it be that metal structure affects somehow, but there aint nothing too near magnets
Equ apo headphone correction was stucked. reboot my laptop 3 times.
un equalized tpl200 without horn and cover from 30cm
Are you using a cap in front of the TPL to protect it from eventual digital xo failure? If so, what are you using?
listening spot measurements right and left
My room bullies nmb´s so bad they cry. it´s all compromise, on this setup i miss my old genelecs which were awesome on lower midrange, damn PHL
just damn
here´s xo´s and youll see eq too
- Manninen presents: Steel is Real
