Monsoon speaker parts
music soothes the savage beast
Joined 2004
Actually, Monsoon used natural rollof of that tweeter to cross it at 1500 Hz. I would cross higher.
Joined 2004
Main reason for two tweeters is impedance, I do not like 4 ohm speakers. Now its all 8 ohm.
All glued together. Now to the crossover. I am thinking 5kHz. Mainly because I want to suppress that 7kHz bump on mid, plus it will relieve tweeter from overexcursion. It may be capable 1.5kHz, but why push it.
Joined 2004
Started working on the crossover. Just 4uF for the tweeters, and 0.25mH for mid planars. 5kHz first order. Thats what i normally prefer if drivers behave. I try flat response and phase.
Measured response when tweeter and mid were wired in the same polarity (blue) and oposite polarity (brown).
Cleary cap is swithing in first order, tweeter needs to be flipped.
Joined 2004
I worked a little on midbass crossover, since its raining. Got second order working ok. This is how it looks with 150Hz high pass by simple active crossover and 300Hz low pass.
Just to bridge 15" woofer to the planar mids.
And the response of midbasses with planars
Joined 2004
Total system response. Yes, there are room modes. Its a small room and no eq is used. Sounds ok. After some more painting I will test it downstairs in the main system.
Reactions: 1 user
