ok, after weeks of reading through the forums here and weeks of hacking through spice, schematic capture and breadboards, i think i've come up with a pretty good start towards a complete solution DAC. i've attached the schematic.
details:
input:
the input section of the DAC uses a PLL-mode DIR9001 with the garden variety TORX147 TOSLINK receiver. i went with TOSLINK because my PC has no coaxial output. the DIR outputs 24-bit data, and all digital elements in the chain following the DIR use the same resolution.
asrc:
the asrc is a SRC4193 (SPI-controlled) that is clocked by a (relatively) low-jitter XO at 24.576MHz. from the front panel, resampling may be set to three modes: OFF (bypass), 48kHz (CLKI/512), and 96kHz (CLKI/256). the ASRC automatically mutes the audio stream when it exists in the non-ready state.
digital interpolation filter:
more boilerplate, really. the DF1704 is used to split the stereo data into left- and right-channel data streams for the downstream DACs, using a slow-rolloff filter.
digital-to-analog converters:
and more boilerplate, at least as far as the schematic goes. two PCM1704U-Ks operating in 24-bit, non-inverting mode => single-ended outputs.
iv converters:
the i/v converters are discrete mosfet converters, essentially modified NP D1 stages. spice shows 0.0055% THD at 1.5mApp@1kHz input, 4Vpp output. the frequency response of the circuit is close to 2Hz-50kHz, -0.1dB. loading the output transistor with a constant-current sink helps both THD and frequency response.
motherboard:
two momentary pushbutton switches, one for power and one for resampling mode selection. one power led, one led to indicate if resampling is enabled, two leds to indicate resample rate (if enabled), and one led to indicate PLL lock/unlock. (the DIR sends its ERROR signal to the micro for this purpose.) the micro also controls relays which switch the power to the digital electronics. during the "off" state, the i/v converters are still powered to keep them warm and stable.
power supplies:
the raw power supplies are essentially garden variety, with the addition of mains filters and common-mode chokes to limit HF noise. amveco dual toroids are used throughout. rectifier diodes are bypassed. the +/-5Vdc and +3.3Vdc supplies are switched by omron G2RL power relays.
i/v converter regulator:
this is a dual-rail salas v1 shunt regulator, where the JFET has been changed to a current-regulating diode (4.7mA). under load, the positive rail sources a constant current of 175mA with 50mA into the shunt. the negative rail sources a constant current of 85mA with 55mA into the shunt.
low(er)-voltage regulators:
the logic voltage regulators are salas shunts just like the i/v converter regulator, but they all output 12V. they're followed immediately by TL431 shunt regulators, which regulate that voltage down to the proper value, which will be adjustable by trimpots. all mosfet shunts are sinking at least 20mA under load. (as per simulations)
i realize 16 pages is alot to swallow, but given the fact that i've been buried in the work for weeks, i'm sure i've made mistakes or passed up better options... this is my first attempt at a dac circuit, so i'd really like to know what you think, so, questions, comments, sniiiide remarks?![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
thanks!
~ brad.
details:
input:
asrc:
iv converters:
motherboard:
power supplies:
thanks!
~ brad.
What input sample rates are you proposing to accept? The 1704 will go up to only 96k with the DF1704.
Why select the slow roll off in the DF1704? Its performance looks 2-3bits poorer in stop band rejection than the normal setting.
Oh, and while I'm asking questions... given that you're concerned about RF ingression from the mains, why toroidals?
If you wish to bypass the sample rate convert, the input sample frequency must match the output. This means you need two clocks: one for the 44.1 family and one for the 48K family. With the clock you specified, you will not be able to bypass the asrc for 44.1K material.
i was under the impression that, given the fact that i can also set the mode of the ASRC, i can concurrently set bypass and set both input and output to slave in order to accept 44.1kHz without resampling.
i'm happy with 96kHz, as i chose the PCM1704 for its true multibit characteristic.
but doesn't the slow rolloff exhibit less passband ripple?
i figured, while i can use a mains filter to reduce RFI from the mains, i can't really (save from a brilliant case layout) reduce stray flux from E-I cores et al... toroids pass that much more rf?
thanks for the feedback!
~ brad.
DACs generally perform worse when made to run faster. There's more error from settling time as a proportion of the total, also since there are more samples to output, there are more glitches. So I'd suggest getting rid of the DF1704 entirely and using just the SRC to get to a decent sample rate - it will go just above 200kHz.
How have you worked out that it might? TI seems very, very coy about the close-in passband performance of the slow mode. A plot is very conspicuous by its absence from the datasheet.
Toroids suffer from the disadvantage of having overlapping primary and secondary windings, giving them high inter-winding capacitance, hence much more RF. This can be mitigated somewhat with an electrostatic screen connected to earth. Your point about stray flux is a good one - you could use a bigger case and put the transformer further away as one solution. Screening against stray magnetic flux is rather difficult, even for seasoned professionals. Toroids do suffer from some stray flux too, given that their windings aren't completely axi-symmetrical, so it pays to be able to rotate them to get the lowest induced hum.
i'm a bit puzzled by this. the DF is required to split the data from the SRC into left- and right-channel information... where is "just above 200kHz" coming from?
How have you worked out that it might? TI seems very, very coy about the close-in passband performance of the slow mode. A plot is very conspicuous by its absence from the datasheet.![]()
so i'm better off in all departments to use the fast rolloff in the DF? i guess i should do an in-depth read of the AD1896 datasheet.
Toroids suffer from the disadvantage of having overlapping primary and secondary windings, giving them high inter-winding capacitance, hence much more RF. ...
thanks for that tip, i'll keep that in mind!
~ brad.
haha, ok i feel a bit stupid. i was somehow mentally connecting the slow rolloff mode of the DF with slow servo loop mode (long group delay) of the ASRC...
ok, yeah, i can see that the fast rolloff of the DF would be better in terms of stopband rejection...
~ brad.
Oversampling or not
OK, so now my turn to feel a bit stupid
Yeah, the DF is doing the splitting of the multiplexed audio bus into separate L/R channels, something I'd missed on the first pass. But also it upsamples by a factor of 8. Its this second aspect I was thinking you may well be better off without. Running with an input frequency of 96kHz, your DACs will be blazing away at 768kHz which is definitely going to degrade things.
But of course if we threw out the DF, we'd need to find another way to get the data in the right format to feed to the PCM1704s, so I guess I'd have to think about how to do that the best way... Hmmm.
The 200kHz figure I introduced is the max output frequency of the SRC (actually 212kHz), which means for 96kHz you'd only be getting an oversampling factor of 2.2. However oversampling was introduced as a means to simplify the output filter - the audio bandwidth remains the same, so in my view, if 4X oversampling was good enough for 44k1, then 2X is good enough for 96kHz. Have a look at Dan Lavry's website if you'd like to find out more.
i'm a bit puzzled by this. the DF is required to split the data from the SRC into left- and right-channel information... where is "just above 200kHz" coming from?![]()
This confuses me; what is the reason for following the shunt reg with a tl431?
it seems redundant to me too, but i'm not comfortable operating the shunt regs down near their Vgs(th), so the salas regs for the 5.0V and 3.3V rails output 12V, and then they are further down-regulated...
although, i now have an expert on shunt regulators to ask if there is something better.
~ brad.
as a third option, a BD244C (hfe=~300) in place of the shunt IRFP9240 in my salas reg spice circuit seems to offer reasonable line rejection at Vout=3.3V. in the salas reg thread you hinted that a BJT as a shunt device underperforms a PMOS. would it still be acceptable to power DAC circuitry?
~ brad.
~ brad.
Do these shunt circuits really do a better job than el-cheapo LM317/337 regs with large caps hung off the adj pin?
some threads of interest:
simplistic salas shunt
iko's take on a discrete shunt
dac-end uses salas shunts
according to those who have made measurements and comparisons between series and shunt circuits, the noise floor is lower and sonic coloration is decreased in the shunts. in the tradition of "trust but verify", i'm planning on - once i can afford it - testing these results on my szekeres-based headphone amp, the power supply to which is attached below.
[edit:] the pre-regulator filter caps in the actual circuit are quite a bit larger, if i recall correctly...
~ brad.
Shunt performance
Thanks, very interesting. Certainly ikoflexer's got some excellent simulation results there, but with an output impedance below 1mohm, its going to need to be placed very close to the circuit its regulating to have an effect! Yet its got so many discrete components in it that'll be very hard to implement. So on paper, its excellent, but as an engineering solution it seems to be lacking practicality.
Has anyone done any estimations (measurements and listening) of just how good regulators need to be not to degrade the performance of the circuits they power? I hear lots of talk about low noise/ripple, but just how low noise do we really need? Think I might do some of my own research if nothing's been done...
As for 'sonic colouration' I must confess to being sceptical when there's not really a clearer description of what the effect actually is.
Think I might do some of my own research if nothing's been done...As for 'sonic colouration' I must confess to being sceptical when there's not really a clearer description of what the effect actually is.
i think we both subscribe to the mantra of "trust but verify" then.
as for "how good" power supplies have to be to avoid degrading the sound, it may be a slippery slope. i can say that my lm350k-based reg for my current headphone amp sounds stellar, with zero audible noise, hum, hiss or otherwise in my senn hd595 headphones. doesn't mean "tweakanitis" hasn't set in.
and i couldn't agree more about the practical difficulties of achieving the specs given by the simulator, though many have built the salas shunt, even on veroboard, with great results.
~ brad.
How good do PSUs need to be?
I'm not sure that my approach could be reduced to a mantra
Definitely trust is important, no single person has the time to listen to the effects of every variation of parameter which might effect the sound. But I'd add 'question' in place of 'verify' - I'm always looking for the reasons people give for why they recommend a certain approach. And it turns out that many of the reasons are actually 'religious' ones when carefully examined![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I have a preliminary hypothesis which I'm looking to test. That is that sub-optimal layout and decoupling are the reason many people seem to go for what at first sight seems to be overkill in the power supply department. Many decoupling schemes I've seen result in contaminated grounds, and the lower the ESR (a fashionable thing for capacitors to be nowadays) the higher the contamination of the ground from the rails. So my idea is that if we get the grounding and decoupling right, we won't need such amazing specs for power supplies.
The kind of performance that's being offered in some of the PSU circuits goes way beyond what's necessary to have no measurable hum on outputs, and hiss way below the noise floor of recordings, so I'm still curious as to why...
Did they compare listening to LM317/337 and TL431s with these high performance shunts? I'd be very interested if they have.
i think we both subscribe to the mantra of "trust but verify" then.![]()
i look forward to your research results, if you do, as it's always nice to have others' experienced opinions when designing audio circuits.
as for "how good" power supplies have to be to avoid degrading the sound, it may be a slippery slope. i can say that my lm350k-based reg for my current headphone amp sounds stellar, with zero audible noise, hum, hiss or otherwise in my senn hd595 headphones. doesn't mean "tweakanitis" hasn't set in.![]()
for what its worth: subjective opinions on salas shunt vs three-legged regs.
and salas shunts used to power opa627 opamps.
i'd be particularly interested in measurements and listening comparisons between these high performance shunts and something like a BJT-buffered TL431, as it's currently on my list of possibilities to replace the low voltage salas regs in this design.
~ brad.
~ brad.
Shunts
Hilarious
Ikoflexer saying how wonderful the shunts are in the first thread then in the 2nd saying he doesn't trust his ears. No reason for us to trust his ears if he doesn't is there? I think my hypothesis about grounding can withstand shunt regs improving the sound when compared to LM317/337s as using shunt regs effectively changes the grounding. So its not merely a regulator-regulator comparison.
Yep, me too. I favour the low component count of a buffered TL431, if it turns out the buffering has audible benefits. I could run a sim to see how much improvement the buffer makes... TL431s are so cheap here![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
for what its worth:
Hilarious
- Digital Line Level
- My Complete Solution DAC, RFC
