Need help trying to understand voltage regulators.
Consider a VR tube to be like a zener. Good as a reference but not for high power.
You can however pass one with a FET and get a stable reference with more current capability. This becomes a voltage regulator.
I bread-boarded this simple serial regulator for supplying G2 power. It is based on a 150V gas discharge valve but unloaded output is just a little above the expected 150V. That would be because of the unavoidable FET G-S voltage I presume. Is there a simple way to fine tune the output voltage for a couple of volts?
You can divide down the ref voltage before sending it to the gate. That will allow you to tailor the output to anything below the ref voltage.
But be aware that these ref voltages have a large spread, so for accuracy you may want to use a trimmer.
Then again, how accurate must that 150V be. Is 145V OK? 153?
Jan
Fabulous simple solution indeed, a resistor divider over the 150A1 -why did I not think of that 🙂 While pushing the E130L tetrode the G2 is known as its soft spot. Several people report valves were destroyed by too high G2 dissipation, keeping it safe at the recommended 150V is paramount.
In your vast experience, can you tell me this serial reg has the ability of sinking some current peaks? This article propagates the use of a shunt type. I wondered if an extra gas discharge tube per G2 would be beneficial for this purpose.
As a series regulator it cannot sink current.
You can't just hang another ref tube on this output, as the output and the extra ref never are exactly the same value so either the ref is lower and the reg starts to dump current into the ref, or the ref is higher and doesn't do anything.
You'd need a shunt reg, but are you sure it is required?
BTW If you go for the dividing-down solution, make sure you account for the extra current that division part needs from the feeding current source.
Jan
With that circuit you don't need the tube at all.The CCS there gives a fix voltage over a resistor.
You have have only to pick the right resistor for the wanted output.
Mona
okee, that is speeding things up. 47K should give 145V .. so another 1K8 would be bulls eye. For the bonus of having an adjustable output, would running 3,2mA through a 2K multiturn trimmer (18mW) be acceptable? Adding a little resistance to the 390R will probably bring the collector current down a little. Am I still good at 1mA? Power supply sag will be no more than 12V at peaks, adding another 14V for mains fluctuation, still 130-26=104V remaining. Seems plenty.
Probably a silly idea but could a string of zeners at the regulator output take up the G2 surplus energy when the anode moves far below 150V? Zener noise would probably be an issue.
If the Va goes under 60V the Ig2 increases dramatically at max input swing (Vg1=0V).
Best to choose the loadline to stay above 60V at Vg1=0V.
Mona
Yes, absolutely. The specsheet mentions positive grid voltage on several occasions but I do not see a Class A2 loadline fit to the max dissipation limit :scratch: Edit - they probably mean the supply and not a positive grid voltage as such.
