Glad you find it "incredibly satisfying".
I'd rather be melting some solder.
Hopefully, 6L6 will have some updates in the next day or so.
it takes all sorts I guess
For your interest :
http://www.diyaudio.com/forums/head...esktop-headphone-amplifier-8.html#post4280285
"I must say I'm sold on this whole "match your transistors" thing, even if I did not, technically, match anything .. I just discarded outliers. The improvement, at any rate, over the previous build is substantial but hard to describe. Increased soundstage precision? Yes, but that's not really the main thing. Vanishing levels of grain/glare? Maybe that's closer to it. It's in the way the amp slots away each musical line so gracefully now, softly yet with absolute authority. Previous iterations of the Sapphire, while clean and powerful, never quite reached this level of refinement."
Patrick
Patrick
I posted that because it was from someone who did not believe in matching.
Also he was matching BJTs and not FETs, the former having much less variations between devices than the latter.
One can achieve intrinsic linearity by careful selection of devices (matching including).
Or one can correct for non-linearities by applying heavy global negative feedback.
Using an unmatched source follower pair and applying a loop feedback round it to the frontend opamp belongs to the 2nd variant.
It is also not unlike tube circuits with output transformers placed inside the feedback loop.
Of course everyone is free to choose what he prefers.![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Patrick
Patrick
Patrick, reread what I actually posted. Nowhere did I state that I did not BELIEVE in matching transistors.
I'm well aware of the benefits of matching transistors for certain circuits and do so if required.
My point is the Pass/Colburn circuit appears to be an easy circuit to build WITHOUT the need to match devices.
I'm sure Richard's Sapphire is a nice amplifier and that he's a knowledgeable designer, but I don't buy into things like "reduced glare" just from matching a lot of BC5XX devices or taking the outer plastic sleeves off electrolytic caps for "better sound".
If you buy into such claims...fine.
Even when using opamp with a current booster, there can still be something quite original :
DIYHiFi.org • View topic - Ultralinear "Tube Like" Op-Amp...
http://www.gspaudio.co.uk/soloultralinear.htm
Patrick
Patrick
Next in the queue to try.![]()
I am keen on hearing your impressions on those muses OPAMPs 6L6. Have you had a chance to give them a listen?
No updates for awhile, probably not until the PCB revision.
How does this unit compare to your O2 HPA unit?
Russellc
One can achieve intrinsic linearity by careful selection of devices (matching including). Or one can correct for non-linearities by applying heavy global negative feedback.[....]Of course everyone is free to choose what he prefers.![]()
1. Matching large volumes of transistors is a PITA. However, I do it so you don't have to.
2. In terms of hfe, my BJT lots as-purchased are sprinkled with outliers. Most are fine to use without further binning, but 2-5% are far, far away from the mean. If you end up with one of those in a parallel output stage running open loop, or a symmetry-reliant topology like a diamond buffer, it's going to screw things up. When I used binned transistors, the sound was smoother / less glare. YMMV.
(now back to your regularly scheduled thread)
The 4N35 is a clever way to stabilize the bias current. No downsides that I can see.** MOSFETs are voltage controlled, so its easy to adjust the bias current through the gate voltage like this, and thermal stability comes for free.
** Except in the unlikely case the optocoupler fails. The transistor turns off, gate bias doubles ... unless the source resistors R16,22 are big enough to catch up its bye bye FETs.
I wonder if this trick would work with bjt output stages?
I have bought from this supplier and they seem to be genuine -
B+D Enterprises - Search results for: '2sk2013'
B+D Enterprises - Search results for: '2sj313'
Yes. These are BDW93/94
![IMG_0649.jpg](https://www.diyaudio.com/forums/gallery/data/500/IMG_0649.jpg)
Some modification would need to be made to the circuit to control DC offset, but generally the optocoupler bias works fine with BJT.
6L6,
Thanks for your quick reply. I have ordered some.
Jim
- New PassDIY Headphone Amp (now available)
