I guess you mean 2SK1530 / 2SJ201 ?
Yes. Same here. I cut and pasted from his post!
Russellc
Thanks for the comments. I've been thinking about building an M2 with the Toshiba
mosfets as well. That way I can compare it against a standard one with
the Fairchild parts.
I found the M2 more lively than my Aleph 30, though I do not know how much
the Fairchilds contributed to that.
Dennis
Dennis
Liveliest presentation with FQA, more rocking.
IRF more well tempered.
Over all most convincing SK1530/SJ218 combo, but only with not current demanding speakers.
Do not know why.....
decrease source resistors to 0R33 , decrease that 100R connected ditto to optocoupler's LED to 0 and that's it
...that is music to my ears since i have enough pairs of 2SK1530/2SJ201 left over from F5X to make the 2 M2 Channels
I'll be using 2sk1530/2sj201 as well - which resistors are these? I'm guessing R13/14 (change to 0R33) and R10/12 (jumper). Is that right?
So you meant decrease that 221R to (near) zero, then........that makes more sense. I was a little confused.
ref. to schm in post #1 - decrease R13,R14
decrease R11 to (almost) zero
Iq will go up somewhat , but you ought to have that much reserve in heatsinks
R11 is 221R, did you mean decrease R10 and R12 from 100R to near 0R ?
My M2 displays some hum with speaker sensitivities >100Db or so.
Room treatments for headphone users
My Altecs are more sensitive than that....silence.
Russellc
Nelson has made the comment that a slight amount of hum might be present because of the input transformers. At least I think I remember reading this in the past. I have LaScala's and mine is quite but it probably depends on your horns sensitivity. You may try shielding the input transformers or maybe checking your grounding scheme.
I awoke this morning with anticipation of reading your review of this M2 Russellc and was disappointed earlier by not seeing anything but I guess you were too busy listening last night to bother posting anything. I understand. This amp has reached the top of my FW builds as well.
In my opinion, within its power band, it is by far the best I have built so far.
Beautiful! Brilliant! On the vinyl system, it is amazing, spellbinding in fact...
Russellc
leave them as is , except if you want zener chips go poof when you have few glasses of red more
How close to zero? Is there a range or is it set by source resistor readings, palm test etc...
yeah, I find it hard to get from the 4N35 datasheet to what the resistor values will do to the bias current. Hay anyone modeled the M2 in Spice yet and is willing to share?
My Spice-fu is not big enough for this.
just zero it
according to LTSpice , it'll be around 2A Iq , but I can't confirm that in vivo - amp is too heavy (and in living room) and my back temporary not in best shape
I have FQ outputs in mine (geschenk from Generg) , and yet to install 2SJ/2SK
- Official M2 schematic
