The 16v rating on parts seeing between 18v-25v ain't exactly helping...
I tend to solder the 10/100uf caps by the heatsink under the boards.
That said I do know one guy who had his plugged in and turned on 24/7 for five years before the caps fried, it was a low -current build though, 10ohms. Well ventilated though.
Got a Paradise in today for service and upgrade, one of the local supply rail caps is loose on its pins, perfectly soldered, just wobbling away. It's a Panasonic FC, I've never seen this before in any circuit I've worked on. Mouser sourced parts...
Anyone ever seen a similar failure?
- Analogue Source
- Paradise Builders
