Paradise Builders
I tried to search without success through all the threads. Is it possible to decrease the gain of this preamplifier? I use a cartridge with 0,5mV nominal and the output is still undistorted, but the value is quite high. I cannot use the whole range of the volume control of the next stage. Thanks in advance!
So let's say I want to reduce the gain by 3 times, I would then need to reduce the network impedance by 3, keeping the RxC product the same:
73.5kΩ will become 24.5kΩ; 9.1kΩ + 33.3nF will become 3.0kΩ + 11.1nF and 220Ω + 11nF will become 73Ω + 3.7nF
Is this approach correct or I am completely wrong?
It ain't over til the fat cap sings 😀
My own, limited, biased, totally personal and subjective opinion on this is that the thicker the dielectric, and less Absorption, the better - but the longer it takes to break in.... have you tried PPS2 caps?
