Hi Guys,
I got things working. I had a quick listen, it is one amazing amp. No doubt about it.
I had originally sized my cabinet for one trafo, it is a 14" Par-Metal cabinet. Due to my trafo problems mentioned earlier, I am now using 4 trafos. This eliminated the space inside the cabinet pushing one channel right up alongside shunty and very close to the trafos. Not surprisingly this channel has a pretty big hum If I removed the board amd let it hang outside the box putting some space between board and the supply the hum reduces. It looks like either I have get a new and bigger cabinet or take the trafos out and put them in a smaller cabinet and make a 2 box system.
Can anybody suggest some inexpensive cabinets?? Or could this be solved other ways??
So close, yet so far.
I'm just looking at steen's pics ....... in hope that I can find some adequate pic for dviswa but - naah ........ steen have just two xformers , potted , and Shuntys are between them and Pumpie pcbs ......
anyway , I'm just laughing ....... look at this drek - all that but only 4 active devices per channel (two per leg ) .... !
ZM,
Obviously. I am not in the same league as Steen and have no desire to compete with a master
I am using the Mercury Magnetics TA110-W from ApexJr. 2 Trafos per channel. I also noticed these trafos do produce a good bit of audible hum, the Magnetostriction vibration variety. I tried tightening the screws down to stop the vibration, not much use. Don't know what trafos Steen is using. I am not too keen of pottig the trafos myself . Surely, the trafo vibration is another thing I need to fix. Any ideas on how to dampen the trafo vibrations down?
Dinesh
Dinesh
jacco vermeulen said:Already tried a screen between the TA110s and the pcb ?
Jacco,
No, I have not. What type of screen did you have in mind? Mumetal or something? Yes, that is possible. Any suggestions?
Thanks,
Dinesh
PS: Sorry, I misspoke about the cabinet. I bought the 12" one, not the 14".
dviswa said:ZM,
Dinesh
naah ....... steen is master scavenger , even if he certainly put nice gross of greenies in his scavenging
(steen is my man !)
put these buggers in bucket of varnish or glue or paint ; let them soak for 30mins and pull them out ; leave them overnight in outdoor and pray
nothing better than separate box for noisy xformer ( or noise inducing , whatever )
mumetal will help just a little , if trouble with them is already apparent .
jacco vermeulen said:Why don't you click some pics on the 1st page of this thread and find out ?
Surely clicked but can't be sure!
housing said:
Zen,
You should include them in the Super Super kit.
naah ....... not enough interest ; besides - that's low level operation
main problem is that I don't have them at my vendors local stock ;
every purchase - delivery in 3 weeks
Zen Mod said:put these buggers in bucket of varnish or glue or paint ; let them soak for 30mins and pull them out ; leave them overnight in outdoor and spray
Interesting...
Does it works with donuts too?
Manu
Usually whatever i say, yes, even if i do not use that word.
(you think there's something as "Le sauvage savant" ?)
Not in this case, means : yes, also for toroids but not just that easy.
Maybe the Brittanicos find singularité too lonesome.
Pair of scissors, pair of pliers, pair of spectacles, pair of pyjamees.
(come cosi, cosi come sei)
jacco vermeulen said:yowza
Manu said:
Papiamentu?
masala!
*read as mashala
- Pumpkin preamp - ordered by Steen , official making thread
