Manu said:
Steen : Are you sure you have to change to metal-case? A pity considering your beautiful wood-work. More air flow inside could mebbe cure the heatproblem? No?
All ya guy's are nut's
![smash :smash: :smash:](https://files.diyaudio.com/forums/images/smilies/smash.gif)
Re: Cook Book - few more lines
You dont need to be fluffy, to need those input caps! I am sure I have been very very carefull to do the adjustments. With "very" I do mean very, indeed. I thought the woofer cones would fly through the room, when I first started up the Pampkin
Horrible experience. If you dont like things like that, install the the input-caps![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I didnt find them to hurt the sound in any way, though! Funny enough. I thought it would kill the transparency of the preamp, but it didnt.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Zen Mod said:
- In case that you are fluffy with setting absolute offset (DC voltage between plus and minus
outputs of Pumpkin ) , you'll have replicated DC on both INPUTS of Pumpkin ........ exactly
divided by ratio of feedback net .
That will result in screechy noise during volume pot turning .....
cure is simple - Papa-like ....... just include 2u2 good cap on each input leg (both + and -)
between pot and inputs ; that will block DC to reach pot .
Hehe - that cure is certainly less evil than using any kind of Servo"
regarding these caps - Holger (HB) already sez long time ago that he even will not try hiswithout input caps .........
as usuall , Cook Book can be found HERE
[/B]
Zen Mod said:Steen - I just tried for you that version ( if I'm not wrong - PD's ?) of simple 1543 DAC , feeding 22K input impedance of next stage ;
there is not enough dynamics ; sound is -sorta interesting (different than SSDac with xformers , certainly ) but just with occasional glimpse of life in it ; details are almost there , but everything is somehow flat ;
you'll always know that impedance mismatch is in case , if you have wakoo response of volume control ....... turning it up almost without normal response , and then suddenly you have enough volume ;
purely subjective described ......![]()
Thanks a lot ZM. That pretty much matches my impression. Except that I found on top of that, the sound was Zingy and generally not pleasing at all. I have a few details I want to change. The IV resistors needs to be changed to something totally different. Like RIKEN carbon..... or some really old carbon mass resistors, you know the 1/4 watters the size of a 3-watter....
housing said:Look.........Look!@@@@![]()
Those are really nice looking pictures
BTW I like your filmcaps, indeed
steenoe said:
All ya guy's are nut'sI know I asked for F4 preamp, and I really like the sound of it.... Well, I will simply build the psu into a seperate case, just like the one my Pumpkin is in right now
Surely, two cases dissipates double up on the heat, right?
I have ordered the wood for it allready. BTW its Erocco-teak. Just hope I didnt butcher a rainforest
you'll be surprised if you make it as I wrote - with slots on both sides , on both bottom and upper plates ;
in that case - everything will stay in one box , with enough ventilation
jacco vermeulen said:It's a polyester pillow.
what's price for 4pcs of 5309 , ya dirty dozen dutchie member ?
I'm sticking diodes in a clay puppet while i'm typing this, as it happens the thing looks a remarkable lot like you.
Repeat after me : no one does VooDoo like you do.
Nada from a vegetable grower.
Maybe your lowness can send me a number, plus an adressi that is readable this time, i'll kick them over subito combined with the ma24 junk.
jacco vermeulen said:I'm sticking diodes in a clay puppet while i'm typing this, as it happens the thing looks a remarkable lot like you.
yeah .....
nobody does VooDoo like me.............
![rolllaugh :rofl: :rofl:](https://files.diyaudio.com/forums/images/smilies/rolllaugh.gif)
Manu said:ZM : 5309 are good caps right?
Why do you need some? New project?
1N5309 are sissy CCS-es needed for KSA100 duckies ;
wakoo dutchie does EU delivery of them , and - as usual - he probably made own stash in excessive numbers ( anything bellow 1000pcs is zu teuer for Jaccovitty
I have KSA100 DiyA pcbs , literally thrown in/on my head by one cwayzee SF residented Serbie ,along with AX pcbs .......
now I have obligation to make more children , just to have someone to whom I'll give all my excessive amps (which I must make) ........
besides that - already mentioned wakoo dutchie augmented my curiosity for Marantz MA24 , presenting schematic to my (always hungry ) eyes .......
there is no big enough
or is it :
Manu said:.......
BTW all what you mentioned : I wan't it too!
Manu
what ?
pcbs or amps or more kids ?
![clown :clown: :clown:](https://files.diyaudio.com/forums/images/smilies/clown.gif)
Manu said:......
Kids? Hmm, the problem is, they could look like me ...
Manu
hehe
ya nutz ....
Zen Mod said:stash
Neuh, it's a pro buono publiconus thing to encourage suckers like you to assemble a classic waffle iron.
10 years from now it will be prohibited to switch such a power amp on, it'll be a sleeping beauty in the trunk of a muscle Camaro convertible that's hidden in the subterraneal garage annex nuke shelter.
Usually the problemo arises if they do NOT look like you.
ya dutchie Schwarzenigger's Bruder , have you few more yank copper thingies , to send in Ostrichland ?
there are always only problemos , when you are messing with serbies ;
as I said , I must build that BAF origin mess ...... I'll make biggest headphone amp in the world
Zen Mod said:
there are always only problemos , when you are messing with serbies ...
... and Frenchies ... a real plague.
- Pumpkin preamp - ordered by Steen , official making thread
