Sorry about that Do!
40 units spoken for, 80 unit remaining
xrk971 - 4 units - USA
pinnocchio - 2 units *Pre-order Placed*
Vunce - 4 units - USA *Pre-order Placed*
Miggie78 - 2 units - FINLAND
Nautibuoy - 2 units (maybe 4, depending on price) - UK
gary s - 4 units - AUSTRALIA *Pre-order Placed*
WTL- 2 units - AUSTRALIA *Pre-order Placed*
ppap64 - 2 units *Pre-order Placed*
drpro - 4 units - USA
Alarudin - 2 units - SINGAPORE
Ripcord - 2 units - USA
Myint67. - 4 units - Singapore (depends on price )
av-trouvaille - 2 units - NL
ravid - 2 units - India
darrr - 2 units - Poland *Pre-order Placed*
Avtech23 - 2 (maybe 4) units - Australia
bkdog - 4 units - Australia
necplusultra - 2 units - Dominion of Canada
gannaji - 4 units - USA
Amplitude - 2 units - Denmark
esprit - 2 units - UK
hirscwi - 4 units - USA
yoaudio - 4 units - USA
kamco - 2 units - USA *Pre-order Placed*
Baobei - 2 units - UK *Pre-order Placed*
Kokanee - 4 units - Canada *Pre-order Placed*
Abanico - 2 units - Spain
vasilis - 4 units - Greece
astromo - 6 units - Australia
mlloyd1 - 2 units - USA
markus22ch - 6 units - Switzerland
redjr - 2 units - USA *Pre-order Placed*
gtose - 2 units - USA
jwjarch - 4 units - USA
gktaudio - 6 units - USA *Pre-order Placed*
quadtech - 2 units - USA
livingstone - 4 units - RUS (depends on a price)
Bare - 2 units - Can
Quan - 4 units - Aus
MD_Stryker - 2 units - USA
tuyen - 2 units - Australia *Pre-order Placed*
evanc -2 units -USA *Pre-order Placed*
tcpip - 6 units - India *Pre-order Placed*
Thank you Livingstone from RUS, and "T..." from AUS for your order!
GB Status Update
46 units spoken for, 74 units remaining
GB Status Update
livingstone - 4 units - RUS *Pre-order Placed*
tcpip - 6 units - USA *Pre-order Placed*
"T..." - 2 units - AUS *Pre-order Placed*
GB Status Update. Thanks DrPro! Please remember to give me your DIYA name so i can track the list.
drpro - 2 units - USA*Pre-order Placed*
The circuit is powered from the conveniently available +ve DC rail of the amplifier's PSU (range is circa +20v to +100Vdc).
Specifications:
- Requires > +24vdc power supply (can use +ve rail from your amp)
Looking for clarification given the conflicting detail offered in Post #1.
What's the minimum acceptable voltage that can drive the unit?
Is it +20VDC or +24VDC? I'd suggest that the conflicting data is resolved to avoid confusion / doubt.
I've got a built PSU that's delivering just under +/-21VDC under load.
Can I go ahead with confidence?
What's the minimum PSU voltage that the unit has been tested to?
The internal regulator makes 15v for the circuit to do its job. It’s not a low dropout regulator so I would not go lower than +19v input for a supply to be on safe side. Hope that helps. I will update the 1st post to state this.
Thanks,
X
Excellent. Critical info to be aware of and understand.
GB Status Update
50 units spoken for, 70 units remaining
Vunce - 2 units - USA *Pre-order Placed*
drpro - 2 units - USA *Pre-order Placed*
gtose - 2 units - USA *Pre-order Placed*
Pilcom - 2 units - AUS *Pre-order Placed*
Apologies for my tardy response x but I've removed myself from the list due to a change in project direction. If I need some in the future maybe I'll be able to pick up some of these on your Etsy store?
Hi X, sorry but my projects are on hold... I've taken myself off the list.
Thanks, Ravid!
GB Status Update:
52 units spoken for, 68 units remaining.
GB Status Update:
ravid - 2 units - India *Pre-order Placed*
Thank you, Astromo!
GB Status Update:
58 units spoken for, 62 units remaining.
GB Status Update:
astromo - 6 units - Australia *Pre-order Placed*
Hi Folks,
We are still waiting for the 1st verification unit to be built and sent to us for testing. Thanks for your patience. In the meantime, I am playing with a compact stereo headphone SSR relay DC protection and delay circuit that jhofland designed. It uses a +/- rail power supply and internal +/-5v regulators for operation. Uses dual 13mohm RDSon MOSFETs for a very compact pacakge due to extensive use of 0603 components and parts on the bottom side as well (opto-couplers). Still testing and debugging...
- Group Buys
- Ready-to-Run (RTR) SSR DC Speaker Protection and Delay GB
