Good news!I've found the issue. The pattern is backwards for Q12 in the layout. We can either hack some traces or install Q12 upside down.
Is this a mini N.S Output?
Good news!
It isn't non switching. It's just a standard EF3 output board.
Is this compatible with N.S IPS?It isn't non switching. It's just a standard EF3 output board.
Waiting to see which is betterYes it is
I'm going to wait for Jeff to get the OPS working before I make any changes to mine. Meanwhile, yesterday, while trying to find the issue I started testing the IPS boards to see if that was my problem and had a probe slip and saw a puff of smoke so I know I have blown something but I can't see any damage. So, having said that, is there another schematic for the x4 that is different from the PDF Jeff sent to me? It has a lot of traces that overlay other traces and it is making it very difficult to see what goes where? It is too difficult to probe the tiny pins on the dual transistors.
Thanks, Terry
Thanks, Terry
Don't probe the tiny pins on the dual transistors,using very thin probe just probe resistors where they fitI'm going to wait for Jeff to get the OPS working before I make any changes to mine. Meanwhile, yesterday, while trying to find the issue I started testing the IPS boards to see if that was my problem and had a probe slip and saw a puff of smoke so I know I have blown something but I can't see any damage. So, having said that, is there another schematic for the x4 that is different from the PDF Jeff sent to me? It has a lot of traces that overlay other traces and it is making it very difficult to see what goes where? It is too difficult to probe the tiny pins on the dual transistors.
Thanks, Terry
Don't probe the tiny pins on the dual transistors,using very thin probe just probe resistors where they fit![]()
That is what I am trying to do but I cant read the schematic to see what each pin connects to.
It's a lot easier to see what's happening by checking voltage drops on resistors instead of trying to probe transistors. The resistors themselves act as fuses a lot of times. There's a good chance you blew a resistor and it's now open circuit.
I agree, but on this X4 with the large heatsinks, it is really difficult to get the probes to everything. I didn't want to do that while powered up. with through hole parts you can choose which side of the board you want to probe but with SMD you are limited. Just a learning curve for me.
Agree,eagle eye is what you need.I'll try to shuffle parts around a bit on the schematic and see if I can make it easier to read. This is a real sore spot with Diptrace. Schematics are ugly!
Difficult to read those schematics especially when these printed
Well, it looks like I won't be testing a stereo set of the x4 boards. I had damaged Q7 but when removing it so I could replace it the pad for pin 5 came off with the part. I'm afraid the pins are just too tiny to try to attach a lead of any kind so this board is likely done for. I also learned that I need to use through bolts to attach the little heatsinks since the heads of the screws are facing each other. ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
There's a new version of the VZ-X4 coming. I'm going to shuffle the output end around to fit a large single heat sink.
Reworking gets easier with practice. The remains of your board might be good for this. Blob lots of solder across the pads and pluck it off with two irons. The pads normally only lift if one is too cool.
There's a new version of the VZ-X4 comingThere's a new version of the VZ-X4 coming. I'm going to shuffle the output end around to fit a large single heat sink.
![joker :joker: :joker:](https://files.diyaudio.com/forums/images/smilies/joker.gif)
Well I was bored so I went ahead and cut the traces and installed jumpers to reverse Q12. I also installed a 200R trimmer and changed R34 to 1.2k. One of my boards is drawing way too much current, (the light bulb shines brightly), even with no IPS in place. The other board fires up but I can't get any bias at all, even with the trimmer set to 0R. I may try to put 1k1 back in R34. Still not sure why the one board doesn't work. I haven't found any shorts and all the transistors test fine with diode test. The two boards are slightly different since one is left hand and the other right hand. I wonder if there could be another mistake in the layout in that one. I'll keep hunting.
- Revisiting some "old" ideas from 1970's - IPS, OPS
