Rotel RA-04 channel issues
Hi all.
I own a Rotel RA-04 integrated amp which I bought new back in 2007. All was fine until recently and I’m having issues with the channels.
I’m only getting sound from the left speaker when hooked up to my CD deck, but weirdly I get stereo sound from an AUX to RCA through the amp.
I’ve tried all RCA inputs and the CD deck works fine as I’ve tried it on a spare amp I have.
I’ve also tried hooking up the speakers to Speakers B just in case it was those, but no dice.
Any ideas? It’s a great condition amp and I’d really like to get it working again.
RA-04 service manual cannot be found but RA-06 is available at elektrotanya.
If these amps are not too different then the RCA input sockets of both CD and AUX connect straight to the input selector chip.
So if one channel of CD input s not working then the first suspect would be a cracked solder joint of the RCA socket.
Thanks for the advice. I also tried plugging the RCA from my CD deck into the Tape and AUX 2 ports at the back of the Rotel, but it was still left only speaker. I’m confused as to why my AUX 1 input is fine, but seemingly all others are not. TBH I haven’t tried the CD deck in AUX 1 yet, so that might have to be my next test.
I've tried it with 3 different RCA cables in all the port options and all have the same issue. Same cables and same CD deck into my very old amp (Rotel RA-921) and all seems fine - both channels working and stereo sound. Maybe the 3.5mm jack to RCA is fine because its sending a different type of signal? Going to open up the RA-04 today and see if there's anything out of sorts inside.
UPDATE: Okay, so I plugged the RCA from my CD player into the back of the RA-04 and I only have sound coming from one side - until - I plugged the RCA into the TAPE IN port on the back of my amp. Would seem this is currently the only port on my amp thats prepared to give me stereo sound.
Thanks. Just tried and still without sound to both speakers unless I'm switched from SOURCE to TAPE and RCA plugged into TAPE . If I plug my single 3.5mm-AUX-to-RCA in any port from my laptop headphone out, all inputs work fine and I get stereo sound.
THE CD player tested on another amp works fine on all inputs.
If this uses the TC9163 input selector chip then past experience of these in other equipment suggests that may well be the issue.
Do I understand correctly, when laptop is used as source all inputs work properly. When CD is used as source than only Tape input works?
Iam guessing Here, but if so, it could be some DC offset voltage present on one of CD outputs, making input selector chip not working properly.
Tape-in wont be affected, beacuse it has separate selector further down the line.
Reactions: madis64
