Ads1115 can work in differential mode ,if you specify that in code, so you can utilise it's features, if you have and use differential input .
@ximikas
Yes I read that the chip can handle balanced / SE input's.
Actually I don't have any equipment with balanced output (yet), but my soundcard have balanced input, and I like to have the possibility to use balanced and SE.
Do you have any comment's regarding my schematic ?
Also thinking about the input GND relay switch!?
Thank's...
Thank's...
I think GND is always GND , but maybe you mean relay to ground unused negative input, when using input as unbalanced? Active rectifier circuit looking a bit strange to me, a capacitor to gnd should not be connected to gnd from opamp output. But i don't know this ic , so maybe it allows that and all is ok.
I mean the lower input relay switch witch can be toggled to GND if SE input is provided.I think GND is always GND , but maybe you mean relay to ground unused negative input, when using input as unbalanced?
The active rectifier schematic I found somewhere and it's working pretty good.
The output are smooted out with the capacitor, and the ADC input on the ESP32 is working much better this way, but let's see when I will use the external ADC i'am waiting at.a capacitor to gnd should not be connected to gnd from opamp output
EDIT :: You might ofcause be right here!
Thank's.
Jesper.
Ahhh ups... I made a mistake in my schematic... the input into the attenuator should be grounded, not the input before 😵I think GND is always GND , but maybe you mean relay to ground unused negative input, when using input as unbalanced?
EDIT Like this :
Why would you need that ground switch? The attenuator could stay differential at all times and the source takes one phase to GND if it is SE.
Well mostly because I see that it's on the L|A Autoranger to switch between SE and Bal. on the input ?Why would you need that ground switch? The attenuator could stay differential at all times and the source takes one phase to GND if it is SE.
Also I'am a bit confused about the GND connection's, because when input are grounded, then the grounding on the input on e.g. OPA1656 is grounded through the resistorstring in the input attenuator, giving the GND some resistance.
Not sure if I need a clean GND via a relay there ???
Need a bit of help understanding this 🙂
Jesper.
Actually , conversion from balanced to single ended requires low output impedance of source, in your case , source is resistor divider . If signal is divided twice in converter positive input by 100k/100k , then negative input must be grounded at output of divider. Otherwise signal will be just divided twice, and not amplified twice again by opam , as feedback resistor is not getting proper ground. So negative input of converter must get ground when not single ended mode . Actually , resistances must be equal , probably two buffers needed there, in place after divider and converter to se input.
Hi...
I corrected the resistance values in the input attenuator, and also corrected the input GND connection.
For a start I also added a relaycontactor to the secondary side of the input attenuator.
Relay K9 must then be engaged when used with SE input.
I hope you maybe can explain a bit more what you have in mind @ximikas, now that I corrected the schematic.
Jesper.
Jesper.
Ok ,some explanation. Circuit - balanced to se converter , needs ideally zero ohms source impedance, otherwise not all common mode signal is rejected . If you disbalance resistances , it will work not exactly as it should. Common signal , which mist be rejected ,must have same amplitude on both opamp inputs. Four resistors are 100k , but I'm unsure if converter's input impedance is equal ,for negative and positive input. Also , your voltage divider gives output voltages, but have you specified load resistance in calculation ? There are divider calculation softwares , where you can specify load resistance , and you get lower output with load present . Also it would be harder calculate multi divider like yours , with specified load . Buffer would simplify that, you can calculate as you have no load. But another dual opamp needed then
@ximikas ... 🙂
I need a little time... but in post nr. #32 I attached a .zipped spreadsheet with the values I use + it also calculates with load (I don't know the impedance of my circuit through)
I will along the way, make protoboard test... so it will be a long journey, hope you can help me along? - And other too!
Jesper.
Jesper.
The second opamp is the 2462 rail to rail, which is acting also as protection to the ADC as it cant deliver more than around 3Vrms this way. Due to the input attenuation and the controller ESP32 code, the first opamp (opa1656 diff to se) will never receive more than 0.875Vrms.
I didn't notice any problems, but actually I could also make the second opamp (active rectifier) with +/-12v because the voltage will never exceed 0.875, but I like the protection the 5v opamp gives me into the ADC through.
Jesper
Jesper
I mean you can reduce supply voltage for first , because mostly it just limits output voltage swing. Let's say you get noise while plugging in input,or short voltage spike , which will pass through first opamp.
Ahh okay... but I will then probably have the same issue with the other opa1656 (gain control). This one also feed an 2462+active rectifier.
I do think that I will have worse THD+N with opamp with +/-5v instead of +/-12v, but actually I don't know for sure.
Jesper.
Jesper.
Look at datasheets of modern opamps . Some have specified distortion parameters for different supply voltages, compare them . Opamps , designed for dual supply , can have benefit with higher supply voltage, but datasheet will tell you that. Difference would be at high gains.
I doubt if opamps in my sound card uses more than +-5v . Also , where from you planning connect sound card input ? Probably after balanced to se converter ? If so , then not to fry sound card is better than try to repair it ,in case of problem .
I will look into the datasheet.Look at datasheets of modern opamps . Some have specified distortion parameters for different supply voltages, compare them . Opamps , designed for dual supply , can have benefit with higher supply voltage, but datasheet will tell you that. Difference would be at high gains.
The soundcard is supposed to be connected at the output tab, top rightside of my schematic.
Pin 1 and 2 for SE output and pin 1 and 3 for balanced output (all the way from input to output balanced signal is possible)
* Not sure if I should let the unused OUTB in SE configuration float here ???
* Wil it be a good idea to have a buffer there also??? I can't see why that is 🙂
Hm , sound card with balanced input ? I don't know how much volts their input can withstand, as i see you use +-12V for gain control stage too. In case of ic failure you get almost supply voltage to output jack, maybe you should include there resistors like 100 ohms, several diodes in series, for both polarities, which should never activate with signal in range, also dc blocking capacitors like 100uf .For simple sound card with 3,5 line input jack i suppose signal level is max 2V , so there should be enough 3-4 diodes in series for one polarity, but for balanced i don't know.
Unused output makes no problem i think, its not input, it will not pick-up noise. Making it disconnected from output jack in single ended mode will need to use additional relay , but you can do that.
About buffer - you have two voltage dividers , and several loads , and dual opamp may be included there , as first stage after dividers.
- Design & Build
- Equipment & Tools
- "Sense" circuit for MCU ADC (STM32 / ESP32 / Arduino etc...)
