Yea, it's easy when you know the voltage gain...even Andy and Pepennino already know that calculus
Not if you're stupid!it is evident from schematic ...... and info about xformers used
Quick question. How do I calculate power dissipation in the parts that need heatsinking? The 9140 and the SIT?
So far, I was just using IV to do a rough calculation, but would like to figure out for each part now.
I don't expect a problem with the lowish bias I'm going to use.
Randy
Randy
Choky,they are certainly more clever than Moi
choose 600:600
https://edcorusa.com/collections/ma...-matching-transformers?variant=41109443346619
No one is smarter than you (except maybe Papa) and you never, ever make mistakes!😉
I ordered the Edcors. I’ve got other projects to do until they get here in May! But thanks!FYI, if you call soon, you should be able to cinemags soon. They have scheduled a run of them in a few weeks.
you know , I really thought long and hard about thatChoky,
no wonder that Papa is smarter than even Mighty Moi - I did taught him everything I know, then he did some tricks of his own!!
fact that he's slightly older than Mighty Moi, so he was making speakers and amps on day when I was born, is irrelevant - those talented guys are good even at precognition routines !
go figure ......
![rolllaugh :rofl: :rofl:](https://files.diyaudio.com/forums/images/smilies/rolllaugh.gif)
Did you build the Singing Bush?davidjt,
Welcome to the club. I think your in a good shape with the SITs you have. The SissySIT is a great amp. I love mine and the next in the cue for me will be the Singing Bush. I would have already pulled the trigger but a pair of SS magically came into my possession thanks the codyt and NP.
Just remember you can’t have to many amps.
Another very happy greedy boy!
I have set up the second channel of my SissySIT, which went swimmingly, and have been listening to music in stereo through some proper speakers, albeit a pair of old Mission floorstanders and via dubious temporary hookup wire/connections. I'm using my Noir headphone amp as a preamp as the source is currently just my smartphone (playing FLAC media files) - the 6dB gain of the Noir is just right. I can already hear how good this amplifier is!
The only minor issue is a tiny bit of transformer buzz that I'll need to check out, though it is inaudible unless you're within a metre of the amp.
All I need to do to finish the project is to fabricate front and rear panels and hook-up the socketry.
Thank you Mighty ZM.
![RRIBEz1.jpg](https://i.imgur.com/RRIBEz1.jpg)
- SissySIT R.3
