The zener version improves supply rejection dramatically. The original GB design has excellent AC rejection, but allows the bias to collapse if the supply rails sag under load or low mains
So which poison to pick?
Thanks for the info Mike.
However, the schematic in post #31 from Greg Erksine does not show the updated RCR values and PauloPT confirms in post #30 that the RCR mod replaced the Zener mod. So should one assume that the updated RCR mod enables easier stabilization of the amp, measures better (PSRR) and sounds better as well? ....just logical ramblings, because I am interested in designing a single sided PCB and building. Thanks.
Joined 2009
when all the air cons go on
you mean you actually turn them off sometimes
Many countries are relaxing their rules on voltage and frequency stability of the mains supply these days to cope with too much unpredictable "green power"
In Malaysia power demand in hosing areas peaks in the evening, when people go home and turn their air cons on, drawing heavy load until the rooms have cooled down.
The distribution system was not built for the load and this makes the supply at the wall socket unstable
D
Deleted member 148505
My first iteration for the PCB design for this amp. ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I am still aligning the labels hence no component name/values.
PCB size is exactly 3.35 x 3.85 inches
Less than 10x10cm so that pcb manufacturing will be cheap
D
D
Yes, all vertical mosFETs are GDSWhat's the pinout for IRFP9240/IRFP240? Is it G D S?.........
All Lateral mosFETs are GSD.
- SKA GB150D now public domain...
