Anyone following along is welcome to check out the link below.
What is nice about the wiki is that it can be updated. Notice
thimios' posts above as he has two posts to provide better information
about the CFA and VFA boards. Clarifying, adding to the number of posts
at this time, post #8421.
Nice as the wiki was updated by me with thimios' information
with no additional posts there. : )
Slewmaster Resources - diyAudio
Once these posts get burried by another 100 or so posts
you can find what you are looking for over at the wiki.
I tried to order some 5p ops from pcbway using gerbers I found somewhere in this thread, they sent me an email:
"But I am sorry that there isn't keep-out layer (board outline) in your file, would you please check it and re-upload the fixed file on our web?"
Does anyone have gerber files for the latest version 5p ops with everything needed to order from pcbway? I'm also looking for gerbers for Spooky ips.
Look for a set of gerbers posted by jwilhelm, I believe he re-exported gerbers after the first set did not pass muster. I don't recall the nature of the problem. Should be posted here:
http://www.diyaudio.com/forums/solid-state/248105-slewmaster-cfa-vs-vfa-rumble-765.html#post4352758
As for some of the IPSs or the older OPS look for my files posted here:
http://www.diyaudio.com/forums/group-buys/257057-slewmaster-project-boards-28.html#post4173413
That's the file I sent them. Does anybody have one with board outline?
Thanks for the link to the IPS'
I've produced a new set of Gerbers from that file.
I have the source file and can re-export them if needed. I will download the file set and have a look just in case the file is there and just not recognized by file name.
Edit - I see Jeff is right on the ball this evening and beat me to it. Thanks Jeff.
The sprint file was in the folder. There was no board outline drawn on the board. From what I could tell it was the complete latest board otherwise. OS posted a finished file somewhere, but I couldn't find it.
Since the minimum order on pcbway are 5 boards, I try to figure out what to do with the 3 spare boards.
4 channel amp for active x-over comes to my mind.
Do you guys think my heat sinks can handle a 5p ops on the lower part with a 2p ops above?
The sinks are roughly 300x200mm + the extensions in both ends, total length 390mm.
![334720d1440497457-yngve-bygger-honey-badger-og-annet-sma-tteri-dsc_0561.jpg](https://www.hifisentralen.no/forumet/attachments/diy-og-utvikling-ha-yttalere-forsterkere-etc/334720d1440497457-yngve-bygger-honey-badger-og-annet-sma-tteri-dsc_0561.jpg)
Kypton ND with Lateral Mosfet
Hello guys , I have simulated the Kypton ND with Lateral MOSFETs in the output stage and for now I came to this result . Note that at the time all references of the components are not equal to the original scheme Ostripper.
Could-you publish comparative measurements between the BJT and Lateral version ?Hello guys , I have simulated the Kypton ND with Lateral MOSFETs in the output stage
Distortion, bandwidth, Slew-rate and damping factor ?
Thank in advance.
And how about the ltspice files tooKypton ND with Lateral Mosfet
hangin there, it was done in orcad, mind posting the orcad design plsKypton ND with Lateral Mosfet
And how about the ltspice files toothx in advance
hangin there, it was done in orcad, mind posting the orcad design plsi could help you with the layout.
Hi Savas,
Yes, it was made in OrCad.
In the moment I am at work...soon I will send the xxx.opj for you.
Do you will make layout with Layout ?
Thank in advance.
Hi Esperado,
About BJT in the OS I'm not simulate yet. In your experience, double or triple darlington will match to this version? What did you think about this my version of Ostripper's Kypton-ND ?
I will take a look at it. what version was it done in?In the moment I am at work...soon I will send the xxx.opj for you.
15.7
- Slewmaster - CFA vs. VFA "Rumble"
