Beautiful work. Good layout too, I actually use it in one of my amps, and it maximises space usage.
Congratulations, Pavel, a perfect set of figures. How does it sound? Are you ready to wax lyrical into a typical audio critic review?
Hugh
Hugh
Thanks for your kind words, Hugh.
I like the sound, it sounds like complementary-differential JFET input followed by MOSFET VAS and BJT driver and output stage, with moderate feedback. I do not know if this description helps, but probably you might imagine what it sounds like. Very good space and imaging, detailed but not cold, not dry and not over-analytic.
I guess the JC-1 would sound similar.
Best regards,
Best regards,
Built better than 99% of any hi-end amp available. Absolutely stunning work Pavel.
Kind regards
Nico
Kind regards
Nico
Thanks again, Bonsai and Nico.
This power amp has been commercialized, as you can see in the following link:
http://www.studioeso.cz/huzvu/novinky.jpg
Regards,
Regards,
