Feed them of raw DC across the reservoir capacitor
Boo Hoo
![bawling :bawling: :bawling:](https://files.diyaudio.com/forums/images/smilies/bawling.gif)
OK then with the dummy. Now measure voltage drop across R101 (or R301). So we know we have enough current. Then make sure the four wire connection to the dummy is correct by comparing to the wiring photo in the guide. If those two steps are good, then we will look in the red leds correct orientation, small transistors correct position and health, and in Mosfets health.
OK 150mA spare then. That's good enough, kinda hot-rod. Inspect for correct red leds orientation now. Also make sure there is a proper bridge in unused places of the voltage set components (in the see text outlined area). We want the voltage setting parallel leg unbroken.
I have a question about heatsink size and whether I should make some alterations.
I need 250mA and currently have 550mA CCS (measured voltage drop across R1 and divided by R1 value). is this too much, should I alter the value of R1? The heatsink on Q106 gets quite hot, I can touch it but it is at the upper limit of what I can comfortably touch for a couple of seconds (the baseplate it's touching gets warm for a few cm around the heatsink), do I need a bigger heatsink and would it hurt to get one say 120mm by 50mm by 50mm and have both Q101 and Q106 attached to it?
- Power Supplies
- SSLV1.1 builds & fairy tales
