Dear All,
Please find output below:
tc@piCorePlayer:~$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Tone1 [Tone1], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Subdevice #0: subdevice #0
tc@piCorePlayer:~$ cat /home/tc/camilladsp/44100.yml
devices:
samplerate: 44100
chunksize: 4096
queuelimit: 1
capture:
type: File
channels: 2
filename: /dev/stdin
format: S32LE
playback:
type: Alsa
channels: 2
device: "hw:0,0"
format: S16LE
filters:
clipgain:
type: Gain
parameters:
gain: 0.0
inverted: false
Baseboost:
type: Biquad
parameters:
type: Highshelf
freq: 80
gain: -6
slope: 6
pipeline:
- type: Filter
channel: 0
names:
- clipgain
- Baseboost
- type: Filter
channel: 1
names:
- clipgain
- Baseboost
Many thanks!
Subdevices: 1/1
devices:
samplerate: 44100
chunksize: 4096
queuelimit: 1
capture:
type: File
channels: 2
format: S32LE
playback:
type: Alsa
channels: 2
device: "hw:0,0"
format: S16LE
filters:
clipgain:
type: Gain
parameters:
gain: 0.0
inverted: false
Baseboost:
type: Biquad
parameters:
type: Highshelf
freq: 80
gain: -6
slope: 6
pipeline:
- type: Filter
channel: 0
names:
- clipgain
- Baseboost
- type: Filter
channel: 1
names:
- clipgain
- Baseboost
Many thanks!
aplay -v -D hw:0,0 /dev/zero --dump-hw-params
I'am not on my Linuxbox @ home right now, but does this command tell you excatly what is accepted on the DAC Henrik?
If so, this is something i need to write into my guide, for use in troubleshooting
Jesper.
Fra8123::
Maybe you can try the command Henrik suggested, and then maybe try to change the parameters marked in BOLD & RED below ::
Test with the commands i suggested yesterday ::
Change parameters and rerun
Until no Error's!...
Good luck![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Jesper.
Code:
sudo squeezelite-cdsp.sh stop
/usr/local/bin/camilladsp /home/tc/camilladsp/44100.yml -vv -p 1234
Code:
Good luck
capture:
type: File
channels: 2
format: S32LE
playback:
type: Alsa
channels: 2
device: "hw:0,0"
format: S16LE
Jesper.
Hi Jesper,
Some good news, I have changed S32LE in playback as well and now it is better. Actually my DAC is working 24 or 32 bit. My apologies for my mistake.
Output below:
tc@piCorePlayer:~$ /usr/local/bin/camilladsp /home/tc/camilladsp/44100.yml -vv -p 1234
2021-01-29 12:06:37.288 DEBUG camilladsp - Read config file Some("/home/tc/camilladsp/44100.yml")
2021-01-29 12:06:37.289 DEBUG camillalib::biquad - a1=-1.9806297 a2=0.98072064 b0=0.5031917 b1=-0.9926435 b2=0.48954293
2021-01-29 12:06:37.289 DEBUG camilladsp - Config is valid
2021-01-29 12:06:37.289 DEBUG camillalib::socketserver - Start websocket server on 127.0.0.1:1234
2021-01-29 12:06:37.290 DEBUG camilladsp - Wait for config
2021-01-29 12:06:37.290 DEBUG camilladsp - Config ready
2021-01-29 12:06:37.290 DEBUG camillalib::filters - Build new pipeline
2021-01-29 12:06:37.290 DEBUG camillalib::filters - Build from config
2021-01-29 12:06:37.291 DEBUG camillalib::biquad - a1=-1.9806297 a2=0.98072064 b0=0.5031917 b1=-0.9926435 b2=0.48954293
2021-01-29 12:06:37.291 DEBUG camillalib::filters - Build from config
rocessing - build filters, waiting to start processing loop
2021-01-29 12:06:37.291 DEBUG camilladsp - Capture thread ready to start
2021-01-29 12:06:37.297 DEBUG camillalib::alsadevice - Opening audio device "hw:0,0" with parameters: HwParams { channels: Ok(2), rate: "Ok(44100) Hz", format: Ok(S32LE), access: Ok(RWInterleaved), period_size: "Ok(1024) frames", buffer_size: "Ok(8192) frames" }, SwParams(avail_min: Ok(1024) frames, start_threshold: Ok(3072) frames, stop_threshold: Ok(8192) frames)
2021-01-29 12:06:37.298 DEBUG camillalib::alsadevice - Audio device "hw:0,0" successfully opened
2021-01-29 12:06:37.298 DEBUG camilladsp - Playback thread ready to start
2021-01-29 12:06:37.298 DEBUG camilladsp - Both capture and playback ready, release barrier
2021-01-29 12:06:37.298 DEBUG camillalib::filedevice - starting captureloop
2021-01-29 12:06:37.298 DEBUG camillalib::alsadevice - Starting playback loop
Once done I run the commands:
sudo /home/tc/StartServer.sh
sudo /usr/local/bin/squeezelite-cdsp.sh start &
sudo filetool.sh -b
The good new is that it worked until the reboot. After the reboot it is unfortunately giving again the same error as before and it does not want to work.
I still strongly suggest that the best way is to rerun the commands of the amended guide, in order to remove any doubt users do something wrong or with the wrong order.
Thank you so much!!
Output below:
sudo filetool.sh -b
Thank you so much!!
Hi... very good new's...
You need to have two lines executed at boot to start all the stuff automatically...
Edit the /opt/bootlocal.sh file to include the two lines in BOLD ::
And then execute
Then everything should work as expected...
Jesper.
Code:
#!/bin/sh
# put other system startup commands here
GREEN="$(echo -e '\033[1;32m')"
echo
echo "${GREEN}Running bootlocal.sh..."
#pCPstart------
/usr/local/etc/init.d/pcp_startup.sh 2>&1 | tee -a /var/log/pcp_boot.log
#pCPstop------
[B]/home/tc/StartServer.sh
sudo /usr/local/bin/squeezelite-cdsp.sh start &[/B]
And then execute
Code:
sudo filetool.sh -b && sudo reboot
Jesper.
Yes exactly, there is a little more details here:I'am not on my Linuxbox @ home right now, but does this command tell you excatly what is accepted on the DAC Henrik?
Jesper.
camilladsp/devices.md at develop * HEnquist/camilladsp * GitHub
Fra8123...
Remember to disable squeezelite at boot in pCP webinterface
Jesper.
Hi Jesper,
As you know squeezelite is disabled in the pCP web interfaced, you asked me to do one week ago (Audio tweaks ->Squeezelite -> No).
Furthermore, as for the guide I edited the file when I did the procedure two weeks ago:
#!/bin/sh # put other system startup commands here GREEN="$(echo -e '\033[1;32m')" echo echo "${GREEN}Running bootlocal.sh..." #pCPstart------ /usr/local/etc/init.d/pcp_startup.sh 2>&1 | tee -a /var/log/pcp_boot.log #pCPstop------ /home/tc/StartServer.sh sudo /usr/local/bin/squeezelite-cdsp.sh start &
But it is still not working
![ohno :Ohno: :Ohno:](https://files.diyaudio.com/forums/images/smilies/ohno.gif)
Kind Regards.
Fra8123... We are close now...
So if try to reboot the Pi, can you try to execute ::
Let's confirm that this is started at boot? --- If it's running try next step ::
When it's running it gives the output ::
Try it..
Jesper.
Code:
ps aux | grep main.py
This should give the output, if the GUI (Webinterface is running) ::
tc@TestRig:~$ ps aux | grep main.py
8493 tc 0:01 /usr/local/bin/python3 /mnt/mmcblk0p2/tce/Camilla_Extensions/camillagui/main.py
15736 tc 0:00 grep main.py
Code:
sudo squeezelite-cdsp.sh status
Running processes:
PID User ELAPSED CPU Command
15880 root 0:42 0:00 /usr/local/bin/python3 /usr/local/bin/samplerate-daemon.py
15881 root 0:42 0:01 /usr/local/bin/squeezelite -n SuperPlayer_TestRig -o - -a 160:4::1: -b 10000 20000 -s 192.168.1.29 -U -U -d output info -f /var/run/squeezelite-log.fifo
15882 root 0:42 0:01 /usr/local/bin/camilladsp /home/tc/camilladsp/44100.yml -p 1234 -g-3 -l off
Try it..
Jesper.
Hi Jesper,
Almost there...and I am doing baby steps bur close. After the reboot, in order to make it works I have to rerun, for a strange reason, the commands:
So, please find below the output before running the commands above:
tc@piCorePlayer:~$ cat /opt/bootlocal.sh
#!/bin/sh
echo
#pCPstart------
#pCPstop------
tc@piCorePlayer:~$ ps aux | grep main.py
8528 tc 0:00 grep main.py
tc@piCorePlayer:~$ sudo squeezelite-cdsp.sh status
Squeezelite player and CamillaDSP is not running.
Output after running the commands:
tc@piCorePlayer:~$ sudo /usr/local/bin/squeezelite-cdsp.sh start
+ Starting Squeezelite player and CamillaDSP...
+ Starting daemon /usr/local/bin/samplerate-daemon.py
tc@piCorePlayer:~$ sudo /home/tc/StartServer.sh
tc@piCorePlayer:~$ {'camilla_host': '0.0.0.0', 'camilla_port': 1234, 'port': 5000, 'config_dir': '/home/tc/camilladsp/configs', 'coeff_dir': '/home/tc/camilladsp/coeffs'}
No plotting!
======== Running on http://0.0.0.0:5000 ========
(Press CTRL+C to quit)
^C
8553 tc 0:01 /usr/local/bin/python3 /mnt/mmcblk0p2/tce/Camilla_Extensions/camillagui/main.py
8559 tc 0:00 grep main.py
Running processes:
8538 root 0:28 0:01 /usr/local/bin/python3 /usr/local/bin/samplerate-daemon.py
8539 root 0:28 0:00 /usr/local/bin/squeezelite -n piCorePlayer -o - -a 80:4::1 -d output info -f /var/run/squeezelite-log.fifo
8540 root 0:28 0:00 /usr/local/bin/camilladsp /home/tc/camilladsp/44100.yml -p 1234 -g-3 -l off
It is working fine until the reboot.
For some strange reason the autoboot is not working. What could the issue be?
Many thanks![up :up: :up:](https://files.diyaudio.com/forums/images/smilies/up.gif)
#!/bin/sh
echo
#pCPstart------
#pCPstop------
No plotting!
^C
Running processes:
Many thanks
Hi Jesper,
Please could you confirm I did this part well, I have some doubt:
My config onboard audio overlay looks:
# onboard audio overlay #dtparam=audio=on #audio_pwm_mode=2
Cheers!!
Should be like this ::
#dtparam=audio=on
#audio_pwm_mode=2
Okay...
When you start by hand the squeezelite-cdsp.sh, use this command ::
Not this one here ::Code:sudo /usr/local/bin/squeezelite-cdsp.sh start
It is only used in /opt/bootlocal.shCode:sudo /usr/local/bin/squeezelite-cdsp.sh start &
Soo... I'am thinking![]()
My mistake, it is just a type error:
I always used the code:
without &.
The issue should be another
Okay Fra...
Can you comment [#] out the line in /opt/bootlocal.sh
Then see if webinterface is running
This will confirm if we can make the webinterface run at boot at least.
If it's running try to start the rest...
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Jesper.
#!/bin/sh
echo
#pCPstart------
#pCPstop------
#sudo /usr/local/bin/squeezelite-cdsp.sh start &
Code:
Code:
Code:
Jesper.
@ Jesper:
I think there is something fishy about the /home/tc/StartServer.sh script. When Fra8123 runs it manually, it doesn't finish and return to prompt. It waits for "CTRL+C to quit". That will cause a problem when the script runs on boot (form bootlocal.sh).
But - the script shouldn't act like that with a command ending with a "&" like you do (from your GitHub):
I haven't installed or tested this myself, and my only gess is that it is the "su" command that don't work with a trailing "&".
Maybe it works if you add a trailing "&" in /opt/bootlocal.sh?
(By the way, the trailng "&" should not be needed for "squeezelite-cdsp.sh", and can be removed)
/ πr
Code:
#!/bin/sh
# Script to start the CamillaDSP server 192.168.1.XX:5000 (with correct IP address)
su tc -c "/usr/local/bin/python3 /mnt/mmcblk0p2/tce/Camilla_Extensions/camillagui/main.py" &
exit
Code:
#!/bin/sh
echo
#pCPstart------
#pCPstop------
[COLOR=DarkRed]
/home/tc/StartServer.sh &[/COLOR]
/ πr
3.14 @ pi r ![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
You proberly have a point there, but i have been using it myself for quite some months on two RPI's here at home.
But it could be, that something else on Fra's machine is stopping the bootprocess before mine is executed?
I will try to remove the "&" from the squeezelite-cdsp.sh start in bootlocal.sh here and see how it goe's...
If someone here know's a better way of starting the "main.py" webinterface "onboot" than scripting it the way i do, please chime in here...
Goodnight ZZzzz...
Jesper.
Goodnight ZZzzz...
Jesper.
Changing the line with "squeezelite-cdsp.sh start" in bootlocal.sh, won't make any difference. bootlocal.sh never gets there. It freezes on the startserver.sh script, that never finish.
Do you both run the same version of main.py?
What is main.py waiting for, and why?
/ πr
/ πr
- PC Based
- SuperPlayer - The DSP_Engine (CamillaDSP) samplerate switching & ESP32 remote control
