Taramps md 8000 1ohm
Hi guyz, I have a stange problem with taramps md 8000 1ohm, like photo the issue is a blown up transistor. I can't read anything, strange issue amplifier still running but output sound is very low. Thank to everyone can help
75v on output 116khz 14.4v dc in
Audio is clean but still low volume and i cant run for more 10 second because 3 component signed on the bottom turns very hot and smell. Halfbridge no problems, this issue in fullbridge never see
Did this problem start suddenly after working normally?
Are you sure it's not a dirty switch or pot that's causing the problem? Have you tried operating all of the pots and switches through their entire range to see if any were intermittent?
DCV measured across pins 9 and 11 of the 20957 ICs?
Is EVERY PS FET being driven by a clean drive signal on their gates?
Pin 9 and 11 14.8v each driver,
i don't know about previous repair, trimmer are all cleaned with contact spray, fet drive signal very low but present 2vpp, square obviously
