What's NMOS?
It's what your avatar is.
What's NMOS?
There are two types of Mosfets:
Tipo nMOS: Substrato de tipo p e difusões de tipo n.
Tipo pMOS: Substrato de tipo n e difusões de tipo p.
Thanks guys
Just finished the Reflektor and it fired ok. Looks promising. very stable on the bench with a 1kr load.
Very easy to set voltage out.
Strangely, I set it to 10.00Vout and it is loosing voltage with time... 10.00 ~9.99 ~9.98.... As it heats up.
I will let it running for a while now.
My choice of 3r3 // 10r for R1 was spot on.... It is running at 250mA.
Yes this is not a ideal case/choise for Zo, but do you think that the overall result is expected to be (even marginally) better than SSLV1.1-MJE version or perhaps worse ?The output impedance would be very uninspiring in that case.
For the REFLEKTOR, could we made a MJE variant for 3.3v Vout as for the SSLV by simply replacing the mosfet shunt ?
yes! use mje for 3.3 to 5v, it is better than IRF 9240 or 9540!
only get it when use measure!
thanks
Didn't know we have such good reputationThis guy is German so I guess he only sells good stuff.
Not as good as the swiss guys but one of the best.
I have been in Germany and know people like quality. I did not find one chinese store in Duisburg or Krefeld.
As it heats up some things change a little, like Vgs, Vbe(s), let it come up and then fix it with the trimmer.
Trimming after it is hot provides very stable 10.00Vout.
What seems strange is that when powered from cold, it takes 10 seconds to reach 10.13Vout and then starts to go down. It takes 10 minutes to stabilize at 10.00Vout.
In all my other regs the voltage only goes up until it stabilizes.
I will now build a second shunt so I can test them in my p2p DCB1.
As far as I can recall, all/most of my Salas type shunt regs dropped in voltage as they warmed up to final operating temperature.
I don't recall which transistors, but one or two had a +ve temp coef.
I never fully understood the temp coef mechanisms to make any sense of how to significantly improve temp stability. Keep it cool works !
Reading Roender's amp with it's various temp coef corrections was a revelation for me.
- Power Supplies
- The simplistic Salas low voltage shunt regulator
