@TboneAK
Knob Aluminum D Shaft 30x28x20mm O6mm Silver - Audiophonics
@jhofland
I suppose that HIFI2000 will give us a link?! But still need taht builders confirm then they´ll start production if 22 ordering reached.
JP
@jhofland
JP
Thanks JPS, that is a practical solution for all with regards to the Yarra case.
When do we know when the case will be on their website to order?
A link posted here would be helpful for everyone.
Also can provide the link for the exact RCA connectors you designed the chassis for - I see the link for the knobs. Are they the Elecaudio ER-107b and 107R from Audiophonics?
Also do you have a link for the input selector extension shaft.
Anything else we need to purchase that is not on the existing BOM?
@TboneAK
@jhofland
JP
would some thing like this be suitable? It also has 6mm hole and supplied with a grub screw to tighten the shaft.
10PCS 30*25mm Silver Anodized CNC MACHINED Solid Aluminum DAC Amplifier CD Player Radio Turntable Potentiometer Knob-in Amplifier from Consumer Electronics on Aliexpress.com | Alibaba Group
JPS, thanks for the latest PDF file.
Can you please confirm your design uses the Elecaudio ER-107R and ER-107B RCA sockets.
Also, do you have a supplier for the input selector switch extension shaft and coupler you have on the PDF marked with part numbers 724.41-170 and 720.6. I can't see them listed with Audiophonics on their website.
Thanks.
Thanks.
Hello,
last PDF.
JP
Wow, that's very impressive. A huge amount of holes and drill and tap operations that we would all have to do ourselves if it were not for these professionally made cases.
Thank you, JPS64 (and I believe we owe thanks to your better half for the CAD work!)
X
Hi JPS64,
Very nice! Can you please ask them to put a link to this thread in the description?
I will have to order 2 at these prices![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
It would not surprise me if we see the quantities ordered to be significantly higher than the predicted 22.
Thank you for working with Modushop to make this happen!
X
X
- Group Buys
- The YARRA Preamplifier/HPA for Melbourne DB Group Buy
