Win some
I got one last night which made IT a Birthday Present to myself.![cloud9 :cloud9: :cloud9:](https://files.diyaudio.com/forums/images/smilies/cloud9.gif)
Seconds! I don't think last night lasted that long. Squeezed in using my work's T1 line. Cool! Never got close to getting one of the 1st Buffs. And an attempt to 'plant' my own ES9008 humbling and 'put me in my place.'
So Brian, seeing how one didn't have a real chance of selecting PS options and with the 3 weeks till May 11.
?A fair question: Can those of us that snagged only a DAC have a chance to add PS as at 'combination' price verses +$45/ ea?
Charles
Charles
Re: Microchip SW
I am working on the manual right now.
The new controller is an AVR ATiny85. I like them much better than the PIC.
The switches are not the same as the older buffalo.
For now, unless I change my mind, There are three switchable settings:
DPLL Bandwidth in 4 steps: lowest, med low, med high, highest
FIR Roll off (fast/slow)
IIR Bandwidth(Normal/50Khz)
Switching between SPDIF and PCM does not require a controller switch anymore.
Just switch the comparator switch on, and wire for SPDIF, or off and wire for PCM/DSD. Thats it!
Cheers!
Russ
phi said:Hi,
I have read most of the first thread about the Sabre DAC but not this one about the Sabre32. I suppose that the PIC with SW is included and that the DIP-switch is to select different settings in a well documented way, or?
//Per
Cheers!
Russ
Hi Russ and Brian,
Tried to get one, but was 1.32 seconds too late ;-)
Guess you will be busy building and distributing all the orders. Any idea when a next batch will be available? I would like to keep shipment of other products on hold until the Buffalo is available.
Matt
Matt
Russ and Brian, congratulations to your web shop design. Everything worked smoothly despite the very large number of calls your server had to handle during the first few seconds after the countdown.
One question:
Not sure I really understand what you mean. I'm assuming you tested a prototype board and I'm also assuming all boards of the first batch will be fully tested prior to shipment?
Kurt
One question:
Originally posted by Russ White
This first batch of buf32S was pretty small because it was untested.
Kurt
Russ White said:...........please be patient we will get the next batch done as quickly as we can.
May I know if there is an indicative schedule for the next batch?
NeoY2k said:Is there anyone in France having a Buffalo32s, preferably in Lyon or Paris?
Nicolas, I don't think there is anyone in France or elsewhere in Europe with a 32S. Pre-orders will start shipping in two weeks or something.
- More Vendors...
- Twisted Pear
- Twisted Pear Audio - Buffalo32S (ES9018 DAC)
