So You can not provide even a link to it? - Because I haven't seen simpler Class AB schematic with Push-Pull VAS, with acceptable results. If You can not find too - Thank You for your opinionThe internet is full of class-AB designs, there is no need to re-invent the wheel.
Actually without proper bias of the output MOSFETs this is more a class C design than B, let alone AB. Must have a ton of x-over distortion.
The MOSFET types are not given but probably need 3V between them to bias in AB. They got just a bit above 1V.
Edit: there is a reason that you cannot find simpler designs on the 'net ...
Jan
Jan
