Well said, you nailed it! $ 1750 for a 'parts upgrade', how gullible can you get??For audio it is down to wallet thinning therapy
The most likely tangible benefit is a damaged PC board.
Jan
Who said good sound comes cheap.not me. they sound awsome.
So speaks a true believer in the power of random glomming of components with no consideration of the physics.You need a high resolving system to get the best out of the foils.audio chain only as good as weakest link.enjoy.
The best answer is to look at the schematic to see which resistors would actually improve things when changed.
Jan,
The low frequency wiggle is really only a problem as you approach rated power. The real reason why you prefer to use other low distortion resistors is that you can get good performance for less money. This characteristic of yours is either good engineering or as the English would accuse you of being “Dutch!” Of course you actually are! 😉
For those who do not know the history of the Dutch versus the English (used correctly!)
https://en.m.wikipedia.org/wiki/Anglo-Dutch_Wars
Jan,
