See Tony's pivoting measurement stand here:
http://www.diyaudio.com/forums/equipment-tools/200198-low-cost-speaker-testing-stand.html
Thanks!
Yes the pivot point is not quite on the front baffle axis, it is about 1" behind it, which does introduce a little error. I could move the speaker back a little further but then I start to get diffraction effetcs off the platform.
edit: I guess you picked that up from the impulse response? I time zero locked it so that time of flight was absolute between the measurements![]()
Tony.
I noticed that there seems to be significant directivity even in the low hundreds, which is unusual. Therefore I thought that maybe it was caused by the increased distance traveled for the greater angles. One inch can't explain the effect. Any idea?
1" of offset is not going to make any difference. I often have 3" or so and I don't see any effects from this.
That depends on the measuring distance. If you're measuring at several feet away, I doesn't matter much, but indoors you might have to measure at a closer distance, maybe 3 feet. Then 3 inches becomes too significant to just ignore.
If you are measuring at distances so close that a 1" offset is an issue then you are certainly too close for valid far field data.
The gating was at a bit over 300Hz so anything below that is not to be trusted at all
At the 30 deg mark I think that they are excellent up to close to 5K being less than 2db difference across the frequency range to that point.
Tony.
Yes, and the frequency can remain quite well matched up to probably 80deg each way, but there are tradeoffs in the process of obtaining this.Is it even physically possible to achieve 180 degrees horizontal 40 degrees vertical CD at the same time ? (Non CD, at some spot frequency, yes)
ask Søren Bech who is Head of Research at Bang and Olufsen
The B&O design is actually licensed, at least during the early days. For the Beolab 5 as example, that kind of design relies on combined reflections. What this does is that it does make the sound a bit diffused. But if the CSD of the drivers stretch out, it seems that it is not a critical factor. You need to place these type of speakers far away from side walls though.
0 and 30deg SPL and Phase (speakers are the ones in my avatar)
Driver polar plot calculated from a Klippel scan at 20KHz
From the calculation reports I have seen, the directivity suggested by Earl is probably the most reasonable in rooms where side walls cannot be further away from speakers than the back walls.
Not too brite... hehe
Hi Dan...
Yeah... that's the curve b4 I used Audessey for in room correction during movies, etc. Contrary to what seems to be the collective perspective here pooh poohing such methods, my results have been pretty positive. i.e. i hear definite improvements in localisation and sound stage on appropriate material after correction vs. 2 channel or matrixed surround modes w/o Audessey. Personally, I believe Audessey works best if you don't expect it to do too much... which I believe I've achieved with this setup.
These are in a pretty size-able room, 2 story slanted cathedral ceiling, maybe 15,000 ft^3 with lots of diffusion, so the treble has plenty of time to dissipate
When I re-run these and do the inverted phase, I'll re-scale to smaller values and also do some smoothing as those were run with minimal back when I first modded the xover.
John L.
John, I'm almost surprised your not still a little bright at 15ft. Have you looked into dropping that treble even more?
Then again maybe not... I just noticed your scale was 15dB.
Dan
Hi Dan...
John L.
I think this is the one that did some calculations based on ITD/IID
AES E-Library Optimum Loudspeaker Directional Patterns
It seems relevant from the description. Care to expound a bit?In stereophonic sound reproduction, the loudspeaker placement and directional patterns combine to create the sound fields used by a listener to locate the apparent source of sound. Accurate localization requires that the loudspeaker directional pattern be designed to take into account the human directional hearing mechanism. A model of human auditory localization is described and then used as a basis for optimizing loudspeaker directional patterns to permit accurate localization over a wide range of listener positions. The results show that loudspeakers should be more directional than current designs, and that the loudspeakers should be angled in toward the listening area.
Thanks,
Dan
http://decoy.iki.fi/dsound/ambisoni...udspeaker directional patterns_Kates_1980.pdf
Copy on the web.
David S.
Copy on the web.
David S.
Kates is looking for a means of compensating for image shift as a listener moves off the mid line of a 2 speaker stereo setup. He solves for polar patterns that give delay compensation at low frequencies and level compensation at high frequencies for position shift (2 patterns). He shows that the polar pattern needs to vary in directionality based on the spread between the speakers (more narrow pattern needed as the speaker spread gets wider).
Since he ends up with directional speakers heavily crossed in front of the listener, I'm not sure why Earl would declare it "not very relevant". Read it yourself and decide.
David S.
David S.
Almost looks like for the ultimate image, you are going to need some sort of dipole/WG combo with a fully absorbed front wall. I believe it was Gainphile who talked about dipoles in a garage with the door open having amazing imaging. The pattern of each section needs to vary though depending on position. Would be something interesting to do. Now I'm getting ideas. This could be dangerous.
Dan
Dan
I know that I've mentioned it a few times.
David S.
Not Earl but I think Kate's view is too simplistic and the paper also only looks at a center image in an anechoic environment. He also believes that direct sound equals localization and reflections equal "ambience enhancement". It can easily be shown that reflections can do both, shift the image (and not just broaden it) and add spaciousness. Build-up and breakdown of precedence is a complex issue.
- What is the ideal directivity pattern for stereo speakers?
