Mark, hang in there! Many here actually believe that CD is virtually perfect, but there is audible improvement with extended bandwith, etc. We are not all crazy! '-)
At this moment, I am listening to a good CD through the OPPO 105 on my 'big' system for the first time in months. Is sounds OK, BUT it is bettered when I listen to DVD-Audio (24-96) or SACD from the same system. That's what I work at this stuff for.
Thanks George for this effort.Mark, hang in there! Many here actually believe that CD is virtually perfect, but there is audible improvement with extended bandwith, etc. We are not all crazy! '-)
Before buzzing off to Bruce Springsteen show setup late this afternoon I had a casual listen from the clothes line/kitchen/nearfield on POS old school one piece stereo powered speaker and found -
- Integer SRC is distinctly preferable to non integer SRC.
- Reduction in SR distinctly reduces audible information.
- Reduction in Bit Depth distinctly reduces audible information.
- Application of dithering distinctly changes audible nature of fundamentals and further introduces audible discordant artifacts.
I can elaborate on the above points as required/asked.
My preference of all the down sampled to 44k examples were the non dithered/non shaped versions including down to 8 bits despite the 'white' quantisation noise/hiss.
To my ear the effective timbre change of noise shaping is unnatural/unacceptable/non musical.
Dan.
Striking (and accepting the personal distinction) suggests the difference is pretty big, which, isn't out of the question, but certainly an exceptional case. Mark, you sure the chain is working right? 16/44 even undithered on downsample vs 24/96 should make for a very subtle change.
Edit to add: I haven't had a chance to make sure my Windows routing is correct to give George's test a decent shake.
For one example,say, starting about 4 minutes in, there are some male vocals that kind of sound like American Indian chanting. In the 24/96 version they are very detailed while remaining smooth sounding at HF, and the vocalist's voice is pretty natural sounding. In the 16/44 undithered version, the vocal is grainy and rough-edged at HF, and even distorted sounding at louder points.
nothing controversial about hearing undithered 16 vs higher res, Myer, Moran verified it, of course listening level matters
There's still effect size to be accounted for.
All this talk about windows routing reminds me of the one thing I do not like about my cheap nasty DAC that Mark keeps making a dig at
. It doesn't have a 24 bit or sample rate light. I have to rely on Alsa which hopefully, like most things linux does what it is told.
But main rig out of commission for upgrades at the moment![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Its pretty easy to see what Alsa is doing. alsa.opensrc.org
ls /proc/asound/pcm??/sub?/status or something like this. its been a few years since I last had to do this. Alsa is far more user accessible than Windows.
You may also get it from alsamixer. If Alsa is configured correctly and your player connects directly it will pass the PCM directly to the DAC without any changes.
What player are you using?
Okay John, explain the benefit.
Might be something fairly simple like the absence of the first stage upsampling digital filter in the DAC, which is normally a half-band type. Half band filters are only -6dB down at Nyquist which means aliasing.
MPD. When I interrogate ALSA is says it's pumping out 24/96 so I have to trust it. Now as only 0.1% of my music is 96kHz that's possible not optimal for quality but i set it when I wanted to listen to an HD download and left it there. Was a bit of faff to get it working, but now it just gets on with the job.
The server was the best money I have spent on musical enjoyment in a very long time
Where did you get that idea?
Half band filters are normal FIR filters with the added constraint that the corner
must happen around fs / 4 of the incoming data. That results in symmetrical
coefficients which halves the number of multipliers, and every other coefficient
is 0, which halves the effort again.
The attenuation achievable is still determined by the number and values of the
remaining filter coefficients.
You cannot extend the useable pass/stop band of any digital filter to
exactly Nyquist without getting problems.
I think it was covered as part of my uni course. But of course I may have misunderstood.
That is my understanding yes. And added to that, the corner is at -6dB amplitude. So we have a filter which is only 6dB down at 22.05kHz. So its fs / 4 for the outgoing data, not the incoming data.Half band filters are normal FIR filters with the added constraint that the corner
This is true, for the stopband. But my comment was about the transition band.The attenuation achievable is still determined by the number and values of the
Yet that is precisely what's going on in a half-band filter. Depending on whether you consider the -6dB point to be pass-band or stop-band. I consider it transition band.You cannot extend the useable pass/stop band of any digital filter to
In MPD set the output to "plughw" . It will pass the audio to the device without changes as long as the device support the format. I can provide more details later. Alsa has several resamplers it can call. Some are pretty poor.
Here is what worked for the players we shipped. This was driving SPDIF from a Juli@ card.
Code:
audio_output {
type "alsa"
name "Digital"
device "plughw:0,1" # optional
You need to adjust this for your hardware settings.
I'll take a badly distorted Picasso for my wall rather than a precise snapshot.
How about a bad reproduction of a Picasso? I can get you one real quick.
Yes, the aliasing is a function of the designer's choice of corner frequency to be at the "magic" 20kHz. Apparently most of the industry thinks it's better to allow some aliasing than be reasonable and shrink the passband a little.
- General Interest
- Everything Else
- What is wrong with op-amps?
