We are talking about 100% though, it was a theoretical comment from both my self and initially from Vacuphile... Consider it a reference point or a base dimension..... If they are ultimately transparent then they will sound the same, we are aware that this is not so in the real world...
100% transparent is 100% transparent. No filter whatsoever.
So 2 components 100% transparent SHOULD indeed sound the same.
I personnaly believe power amplifier technology is closer to 100% than converter's tech...
but anyway, transducer's tech is FAR from being 100% transparent...
The real bottlenecks are the converters.
D/A and A/D converters and also Electric/Acoustic energy converters (transducers)
it's very easy to lose/modify content when something pass through a conversion.
There are all sorts of things you can change in a signal which are easily measurable, but which will not be picked up by our neck mounted sensor pod.
And visa versa … but we can't quantify those yet.
dave
Interesting!Yes, I compared an ADC/DAC inserted in a direct mike feed to a bypass. Many decades ago, this was also done using a 16/44 processor with an all-analog system, with the founder of Linn being the listener. He reported that he could easily hear when the ADC/DAC was inserted before the trials began. Then the ears-only trials commenced. Yes, random results.
Many excuses followed, but thirty years have passed and there's no ears-only data to refute the results. NB: the systems that I tested and that were used for the Linn tests were well-engineered. There could certainly be audible differences in badly designed fashion systems or ultra-cheap units.
According to this, we reached the 'promise land' many decades ago (at least when it comes to digital), and we mostly never knew.
Praise the lord.
if you guys agree that things simple as a cable change the sound considerably
will it make any sense for things complex as a dac will sound the same?
good perceptual lossy codecs are a powerful argument that quite a bit is known about what is "easily heard" vs "difficult to discern" in audio signals and extensively tested with controlled listening
in electronics Signals and Systems theory lets us verify things like ADC/DAC, amplifiers are working way better in the electrical signal domain than the psychoacoustic limits exploited by the codec algorithm developers
it can be a challenge to get all electronics chain signal errors below an extreme overbound such as all errors below the human hearing threshold in quiet while simultaneously producing signal capable of driving 120 dB SPL output through the loudspeaker or headphone
just backing down to "all errors below studio and microphone noise floor over human audible frequency range" seems likely to include many current Audio DAC
Actually I don't think a simple cable, implemented correctly, can change the sound.if you guys agree that things simple as a cable change the sound considerably
But I do not accept all DACs sound the same, my own experiences through the past 20 years tell me otherwise.
Simple turntables, tone-arms can sound different, never mind a complex being such as a DAC.
Interesting!
Perhaps you didn't, but if you read the literature and perhaps done some good experiments, you would have. There are many unsolved issues in audio, getting sonically transparent A/D and D/A is not one of them.
You are correct, I didn't.Perhaps you didn't, but if you read the literature and perhaps done some good experiments, you would have. There are many unsolved issues in audio, getting sonically transparent A/D and D/A is not one of them.
And it looks like I am not alone.
I am jealous though, I sincerely wish I had.
I'm pleased you said "If". Many of us don't agree. Two reasons or this:kensei said:if you guys agree that things simple as a cable change the sound considerably
1. physics says cables (unless faulty or wholly inappropriate) don't change the sound
2. listening tests (i.e. ears only) show that cables don't change the sound
maybe OT but would you elaborate more: how do you define inappropriate?
i have few set of speaker cables where some sounded bright and some sounded dull, all of similar gauge so as current handling, and no significant diff in measured LCR
read this https://passlabs.com/articles/speaker-cables-science-or-snake-oil saves us typing (for speaker cable)
For interconnects Kimber is a good example of something that works more by luck than design. or for real lunacy Dennis Morecroft of DNM.
Disagree, a complete understanding of arm/cart/TT/vinyl requires multi-domain physics with things that are in some cases very difficult or almost impossible to model.
Examples aremaybe OT but would you elaborate more: how do you define inappropriate?
- using un-shielded where shielded is required.
- using very thin wires for high current cases.
- placing signal cables near noisy devices such as transformers.
- using long high capacitance or high inductance cable for speakers, where poweramp is sensitive to it.
I could go on.
please explain, are you saying that two turntables of similar quality, sound identical?
This is funny, if you consider RFI isn't he making "amplifiers out of glass".
Imagine the loss of quality suffered by large all-metal amplifiers!! Would you choose to make a camera out of glass and then fail to notice that the film kept fogging?
You may want to reread the sentence you quoted. He said exactly the opposite of that.
I like Dennis, he used to drive a Lotus 7 and is completely mad. But yes his 3D signal paths are more antenna like than anything else out there.
http://www.dnm.co.uk/images/csdnmtwinfront.jpg You would have to try hard to make something look more home made!
I am sorry I'm confused, must be the wine.You may want to reread the sentence you quoted. He said exactly the opposite of that.
I see the word 'disagree' and that the physics of things (in short) is impossible to model.
If the entire turntable - arm - cartridge, can not be modeled (copied?) is one thing.
I am (was) talking about two turntables (of naturally similar build quality).
Complex electromechanical systems are extremely tough to model, and they also tend to have a lot of variation unit to unit and day to day (things like temperature, creep, and wear).
Electronic systems are far simpler.
- Member Areas
- The Lounge
- World's Best DAC's
