There is also a photo showing the external SRC PCB and Arduino microcontroller for it. Wish I could find an inexpensive alternative that other people could use if they wanted.
Would this one fit the bill? - its just over $40 : https://item.taobao.com/item.htm?sp...6BaMG6b&id=12809416535&ns=1&abbucket=3#detail
Mark,
Did you put small resistors -2 Ohm or so - between dac and opamp? I found that doing so halves the distortion. 6dB improvement for the price of two resistors, not bad.
A question for you: when you say 2 small resistors halve the distortion, I assume you mean 2 per channel? If not, I may be missing something.
Looks like that was for a version 1.04 DAC. The current version appears to be 1.06.
Regarding use of a controller, the 1.06 DAC doesn't seem to need one. It appears to adjust automatically to the input stream with the user only needing to select a hardware input using the jumpers, or maybe using a switch instead which has been wired up to the jumper posts.
Hi Mark
Yes, two per channel between the DAC and the opamp, so one for the + and one for the - dac output. I was very surprised with the results; will post measurements, time willing. But I couldn't go below 2.7 Ohm because the board froze for unrelated reasons. Some further experimentation may be required to find the optimum point.
I also tested this with the 9018 board, but in that case any resistance added in the path between opamp and dac produces more distortion.
The tiny PCB attached vertically by one end of the AVCC opamp has two sets of 10k SMD resistor voltage dividers and two 10 uf organic polymer filter capacitor cans you can see from their sides. That is the reference voltage divider.
I am thinking about the Vref. How about changing the resistor divider with a Vref IC ? I think that could improve THD
Agreed but its important not to fluctuate . I will do some tests this week using the TI VREF monolithic ICs
This is an interesting link in regards with Vref and THD impact (for ADC)
http://www.ti.com/lit/wp/slyy097/slyy097.pdf
Mark,
I will also test this finding...will report back .
- Digital Line Level
- ES9038Q2M Board
