Looking for high-voltage tubes
AX tech editor
Joined 2002
No manual needed. Close enough for government work.
Jan
AX tech editor
Joined 2002
What does this mean? It means that if you place the isolated part of that connector in contact with a (grounded) metal part, there should be less than 1000V between them. A voltrage spec is always 'between two points', you can't have 'a' voltage on a point.
In the picture if you see the connector on the HV meter at the top right, clearly even if the 4mm banana was naked there would be no problem.
So it's all context.
Jan
AX tech editor
Joined 2002
Not sure, depends on the temp of course.
I have an IR temp camera.
The dissipation will be about half of max, possibly natural convection will keep it below 140C.
The definite anode clamp can be connected to a floating heatsink.
Or a small whisperfan should do it.
First I need to measure things, then I can decide what is needed.
No use speculating (or worrying!) beforehand.
It's just engineering.
Jan
AX tech editor
Joined 2002
As long as nearest ground potential surface is kept at distance it should not be a problem.
No, corona is ionisation of the air, even if there is no grounded element in sight.
It is the result of high potential gradients, like at the tip of sharp parts or edges.
That's why you need to place a nice rounded blob of solder on a high voltage solder connection.
Jan
