Old Style DCB1 information
Posted 1st January 2010 at 02:53 PM by Tea-Bag
Updated 13th October 2010 at 12:48 AM by Tea-Bag (updated some more timely info)
The basics on the boards....
The hypnotize is a 1 input/1 output Shunt regulated Direct Coupled Pass like B1 buffer. It has a relay delayed startup to avoid DC problems for the amps. This board (and even Mez) can be used just as a shunt power supply, and their is a thread for this also.
The Mesmerize can use up to 6 muting relay inputs, and is a larger board. All others matters being equal.
Here are some relevant threads.
https://www.diyaudio.com/forums/group...hunt-psus.html
https://www.diyaudio.com/forums/pass-...ml#post1854512
https://www.diyaudio.com/forums/power...t-reg-pcb.html
Attached is a semi-built DCB1 mesmerize. Also the main schematics of the device, in case you need to troubleshoot. The below shot is a bare Hynotize PCB.
Total Comments 4
Comments
Posted 11th February 2010 at 10:01 PM by Tea-Bag -
Posted 12th February 2010 at 05:08 PM by Tea-Bag -
Posted 24th February 2010 at 12:03 PM by Tea-Bag -
Resistors are available from Audio Note,Shinkoh,Charcroft,Takman,Arcol,Mills,Takman,H olco,Allen Bradley,duelund resistor,Kiwame carbon film,M-resist supreme resistors
Shinkoh's were unfortunately sold out in 220k values when i ordered.Posted 23rd September 2010 at 04:08 PM by janpo
