Group Buy for Salas Boards
Posted 17th April 2017 at 06:05 PM by Tea-Bag
DCG-3 preamplifier and DCSTB DC Power stabilizer purpose built for it
The boards are going to be in Matte black, like the PS on the right
Threads for boards:
Building Thread
https://www.diyaudio.com/forums/analo...ml#post4823253
GB Thread
https://www.diyaudio.com/forums/group...ml#post4855022
DCSTB Board $20
DCSTB Board $25
Transistor Kits for the DCG-3 and the DCSTB are available. Full kits are also available.
DCG-3 Transistor Kit $ 40 - includes matched transistors where needed.
DCG-3 Full Kit (includes transistor kit) $75
DCSTB Kits
Note that DCSTB kits only cover half the board. Additionally, if you wish to run at a higher bias and only use one board, let me know and I can make some part substitutions.
DCSTB Transitor Kit $15
DCSTB Full Kit (includes Transistor Kit)$45
So order two if using Dual Mono.
In-Select
Relay based selector board with volume pot input for preamplifier 16.00
GB Thread below
https://www.diyaudio.com/forums/group...ml#post4716031
Folded Simple Phono Preamp
Per board cost is 52.00
RAW Power supply board is 15.00 - Other parts available, see post below and Mini-Bom Section
Link for first post and to build guide
https://www.diyaudio.com/forums/group...ml#post3615620
BIB
The BIB is a low voltage regulator. It includes 2 positive and 1 negative regulator per board. These have been upgraded to 2mm thickness from 1.6mm. Board production costs have risen , cost is 25.00 per board.
The builders guide is available here in the first post, as well as a current and voltage setting calculator to get the other parts.
https://www.diyaudio.com/forums/group...ml#post2571174
The minikits for the BiB are available for 15.00 each. They dont include all parts to complete a section of the board. PRP resistors are no longer being offered.
More details on the Minikits are in the Minikit link below.
SSHV2 - High Voltage Shunt Regulator
Here is a link to the first post of GB Thread which includes the Construction Guide. It also mentions the parts used in the minikits.
https://www.diyaudio.com/forums/group...ml#post2892748
The SSHV2 boards are 15.00 each.
The Resistor Minikits are 9.00 each
The transistor kits are 12.00 each
Full kit to populate board only is 44.00
All mini kit parts are listed in the mini kit BOM section listed at bottom of message
Build up unit pic.
Reflektor-D
Digital power supply board for 3.3-7V
GB Thread
https://www.diyaudio.com/forums/group...ml#post3974245
Board 16.00
Transistor Kit 12.00
Resistor Kit 8.00
Full kit to populat board 44.00
Reflektor-Mini
Same thread as above. It is used for tighter spaces and potentially for more current than the relfektor-D, it has no AC/DC setup. A DCFlexy Boards is recommended for that
Board is 12.00
Full kit to populate board only is 27.00
DCFlexy Board
The DC Flexy is a companion rectification board for use with the Mini or in general. It can take four TO-220 diodes and a Mundorf four pin filter capacitor or any normal two pin capacitor by just deciding on which alternative pads to install the diodes.
A set of two boards V-scored is 16.00
MiniKit BOM section. This links goes to full details of all the parts included in the kits and there respective positions on the board.
https://www.diyaudio.com/forums/blogs...full-kits.html
Threads for boards:
Building Thread
GB Thread
DCSTB Board $20
DCSTB Board $25
DCSTB Kits
In-Select
GB Thread below
BIB
Build up unit pic.
Reflektor-D
GB Thread
Board 16.00
Resistor Kit 8.00
Reflektor-Mini
Board is 12.00
DCFlexy Board
Total Comments 0
