Quasimodo results (ONLY)
Joined 2018
Hello
Did a search on this thread, the original Quasi thread and on Google…found an inquiry, but no results for a Quasi test
I’m looking for Quasimodo info on the Avel Y236651 transformer?
I used this same transformer in a build I’m trying to solve a noise issue in. Hoping someone else might have resorted to using it over an Antek or similar with the supply shortage.
I haven’t had luck finding info on it and don’t have the Quasi board or ability to use a scope right now.
Any chance anyone has the Quasi information on it?
It would be a big help.
https://www.diyaudio.com/community/...asimodo-test-jig.243100/page-101#post-6424902
post 2015
18R works like a champ if you’re using independent secondaries and Cx 10nF and Cs 150nF
Joined 2020
did someone happen to measure the Antek 3218 with the primaries in series (230v)? For 115v I find results in the range of 10 to 12 ohms, would it be ok for 230v too? Thanks in advance.
I didn’t put the primaries in series, but I did a read with open primaries, and there was a slight ring at 10R under that condition. So more damping than when shorted (10R-12R range, or anything less than 22R really). I assume whatever trend prevails with other trafos when the primaries are wired in series vs. in parallel would apply here.
Joined 2021
Many thanks! The 4225 works fine with 15R @115/230, so this seems to be the trend.
Reactions: 1 user
Joined 2010
Hello to All,
Hopefully following thread rules for posting.
I do not have a QModo/Oscope. Would anyone have a test done on an Antek 3230 or 3232, 300VA, 115V primaries transformer's. l have reviewed the results of all the Antek test posted in the results thread, and I am thinking that Cx=10nF, Cs=150nF, Rs=12-18 ohm, will be close. Thanks in advance for the help.
MM
Joined 2017
Toroidy TS50VA 2 x 18 V
Secondaries parallel:
Cx 10nF
Cs 150nF
Rs 12.8 R
Secondaries in series:
Cx 10nF
Cs 150nF
Rs 23.1 R
Secondaries independent:
Cx 10nF
Cs 150nF
Rs 19.8 R
Reactions: 1 user
Joined 2017
Toroidy TS50VA 2 x 15 V
Cx 10nF
Cs 150nF
Rs 18 R
Cx 10nF
Cs 150nF
Rs 44 R
Cx 10nF
Cs 150nF
Rs 13.8 R
Reactions: 1 user
Joined 2020
Triad Magnetics VPT36-690: 115VAC to 2 x 18VAC, 25VA
Cx 10nF
Cs 150nF
Rs 180R (130-180R ok)
Antek AS-3428: 115VAC to 2 x 28VAC, 2 x 15VAC, 300VA
28VAC secondaries (blue-green)
Cx 10nF
Cs 150nF
Rs 30R (up to 47R ok)
15VAC secondaries (brown-brown)
Cx 10nF
Cs 150nF
Rs 4R1-4R7*
*not as confident about this last one, that's a lot of shunting
