DIY ES9018 DAC + LM4780 AMP
Posted 6th January 2015 at 12:30 PM by Maciej Czerwinski
Finished, front:
![Click image for larger version
ID: 1468](attachments/1468d1420493373t-diy-es9018-dac-lm4780-amp-caly_przod_obud.jpg)
back:
what's inside:
This device is built around DIYINHK ES9018 DAC board, with USB to I2C CM6631 converter, also from DIYINHK. USB is the only signal input. Power amplifier uses two LM4780 chips, one per channel in mono-parallel configuration. Power supply for the amplifier is made out of two HP printer power supplies. DAC power supply is more complex, but also uses three, a little bit modified, 12V supplies, wall plug in type, general use ones. Volume regulation (attenuation to be exact) is entirely digital, provided by ES9018 dac chip. It is controlled by PIC16F84 microcontroller via I2C. There is also 3-digit attenuation level display and rotary encoder is used for setting the attenuation level. Details are described in next posts.
back:
what's inside:
Total Comments 0
