DIY ES9018 DAC + LM4780 AMP Details part 1
Posted 6th January 2015 at 12:30 PM by Maciej Czerwinski
DAC:
On the DIYINHK DAC board we can find ES9018 chip and ADP151 1.2V linear regulator (VDD) factory soldered. You have to populate the rest of the board yourself. I have soldered:
- ceramic and electrolytic noise filtering bypass capacitors,
- various resistors, mostly in the I/V stage,
- I/V stage op-amps (4xAD797)
- output signal low-pass filter capacitors.
The board is designed for 6 op-amps with SE output. I wanted differential output, so I have done some modifications, following the ES9018 demo board datasheet.
The I/V stage and power amp schematics (one channel):
![Click image for larger version
ID: 1478](attachments/1478d1420494798t-diy-es9018-dac-lm4780-amp-details-part-1-av_amp_sch.jpg)
When the main power is switched off, the relay shorts the power amp inputs in order to avoid oscillations, generated by I/V stage during discharge of its power supply bypass capacitors, to pass to the power amp.
A/V stage section of the DAC board – one channel, ES9018 chip side (top side in my case). I had no op-amp socket converters, so I had to improvise. You can see four blue 1k resistors of the output low-pass filter:
ID: 1479](attachments/1479d1420494798t-diy-es9018-dac-lm4780-amp-details-part-1-dac_zbliz_pwzm.jpg)
Bottom side – six blue 470pF capacitors (3 per channel) of the low-pass filter and above them two 4700uF op-amp power supply bypass capacitors:
ID: 1480](attachments/1480d1420494798t-diy-es9018-dac-lm4780-amp-details-part-1-dac_zbliz_pwzm_spod.jpg)
USB to I2C converter is simply an external USB computer soundcard using Cmedia CM6631 chip. It is reduced to having only I2S output and two clock signal outputs. I use 45.1584 MHz clock output to drive ES9018 clock input when playing 44.1 kHz sample rate files (1024*44.1=45.1584). The other output is 49,152 MHz, designed for 96 kHz sample rate playback (512*96=49.152). I have checked, that you can use any of the clocks, with any of the sampling rates, and the DAC sound output is always flawless.
Total Comments 0
