Go Back   Home > Forums > Blogs
Old
Pass B1 buffer
Posted 26th December 2011 at 12:53 AM by klewis
Updated 26th December 2011 at 03:47 PM by klewis
Post #166 board layout
omron G6H2 12v relays
Motorized alps pot https://www.ebay.ie/itm/ws/eBayISAPI.dll?ViewItem&clk_rvr_id=300979180833&ite m=250467804650
Post #1062 for relays
Post 1031 cap tweak
klewis's Avatar
Posted in Uncategorized
Views 1137 Comments 0 klewis is offline
Old
Tapped Horn
Posted 22nd December 2011 at 03:34 PM by DougL
Found this Discussion and resources:
https://www.cowanaudio.com/th.html
Views 1460 Comments 1 DougL is offline
Old
47 Labs 0247 "Treasure" unboxing
Posted 21st December 2011 at 04:33 AM by rjm (RJM Audio Blog)
Updated 22nd December 2011 at 10:47 PM by rjm
It's here!
It came in a box the size of a small shoe box.
Curious, delightful mix of the mundane and the exotic, outwardly plain but clearly immense thought and effort has gone into the preparation.
The gorgeous hammertone finish, hand-matched transistors, and ultra-high quality machined volume/selector knobs are the little signs that immediately set it apart from the ordinary.
Click image for larger version
ID:	548   Click image for larger version
ID:	549   Click image for larger version
ID:	550   Click image for larger version
ID:	551   Click image for larger version
ID:	553   Click image for larger version
ID:	554   Click image for larger version
rjm's Avatar
rjm
Views 2491 Comments 1 rjm is offline
Old
The cost of hi-end audio: is it worth it?
Posted 20th December 2011 at 06:16 AM by rjm (RJM Audio Blog)
Updated 20th December 2011 at 06:30 AM by rjm
Having recently actually bought some new (not used, not my own design, and relatively expensive) audio gear, and from 47 Labs no less, the following question has been occupying my thoughts of late:
How much would you pay to not have a component installed in the audio equipment you buy?
The traditional price scheme for audio equipment is [BOM-times-X], where BOM is the cost of the parts used to make it, and X is a multiple to cover fabrication and distribution costs, as well as profit for the various parties involved. My understanding is that for consumer audio "X" is about 4, though companies with strong brand recognition can get away with higher multiples. And do.
The basic problem is this: how much it costs to build and how good it sounds are not the same thing. There is some correlation: a large, high quality transformer is pretty much guaranteed to improve the sound quality, but for the rest, stuffing a pretty box with many cheap...
rjm's Avatar
rjm
Views 1405 Comments 3 rjm is offline
Old
47 Labs "Treasure" 0247 shipping update
Posted 20th December 2011 at 12:19 AM by rjm (RJM Audio Blog)
Scheduled to be delivered tomorrow evening!
rjm's Avatar
rjm
Views 1331 Comments 0 rjm is offline
Old
Zen V4-J
Posted 17th December 2011 at 02:12 PM by alexcp (My DIY projects)
Updated 12th May 2013 at 04:03 PM by alexcp
Now that Nelson Pass published the details of the JFET upgrade to First Watt F2 and that Newark sells power JFETs from Semisouth, there was no excuse not to upgrade my Zen V4 with the new active device.
I replaced Q1 (see the original schematic) with SJEP120R100A; increased R5 to 130 kohm to bias the JFET correctly with Vgs of approx. 1.5V; and reduced R8 to 22 ohm.
The measured result is a nice reduction in THD+N; attached are the graphs for THD+N @ 1W into 8 ohm vs frequency, before and after the upgrade. With IRFP044 as Q1, the distortion was mostly 2nd harmonic (at -65dB), plus some traces of the 3rd harmonic. With the JFET, it is still mostly 2nd harmonic, which is now at -80..85dB, with the 3rd below my measurement floor.
Subjectively, the improvement is remarkable! There is additional detail and depth of the scene.
ID:	544   Click image for larger version
ID:	545   Click image for larger version
alexcp's Avatar
Views 3028 Comments 1 alexcp is offline
Old
Fascinating: SMT attenuator retrofitted into ALPs case
Posted 17th December 2011 at 03:08 AM by rjm (RJM Audio Blog)
https://www.icl.co.jp/audio/att.htm
Less than 3,000 yen, too. Pity it's only available as 100K types, but for tube amps this is a pretty handy little part to have around.
ID:	540   Click image for larger version
ID:	541   Click image for larger version
ID:	542   Click image for larger version
rjm's Avatar
rjm
Views 5577 Comments 3 rjm is offline
Old
47 Labs 0647 "Treasure" CD player diy kit
Posted 17th December 2011 at 02:54 AM by rjm (RJM Audio Blog)
Updated 17th December 2011 at 03:01 AM by rjm
Fancy building your own CD player with built in non-oversampling DA converter from a kit?
Look no further.
Based on a TEAC transport and ye olde Philips TDA1543 for the nonoversampling DAC
DAC is basically the Progression DAC (see DAC of ther Klones) reborn.
or salient details:
-top loading, close to the lit to automatically load the TOC.
- isolated digital and analog power supplies
- ATMEL AVR microcontroller, custom program/operating system
- simple, easy to understand display and controls
- standalone or use as a transport with external DAC
- small footprint, B5 size(W250 × H65 × D175mm)
- comes with a remote!
Although offered as a kit or pre-built, my suspicion is that all the real work has already been done: programming the microcontroller, now that's an area where most DIYers still fear to tread!
Not too many kit/home build CD players...
ID:	536   Click image for larger version
ID:	537   Click image for larger version
ID:	538   Click image for larger version
rjm's Avatar
rjm
Views 7768 Comments 4 rjm is offline
Old
47 Labs 0347 "Treasure" stereo amplifier
Posted 16th December 2011 at 12:33 AM by rjm (RJM Audio Blog)
Updated 19th April 2015 at 11:27 PM by rjm
(regarding the Treasure 0347 stereo amplifier)
Well, think of it as a bulked-up headphone amplifier. The design is one of those "ah, I should have thought of that" moments, but the details are quite tricky, as usual.
If the extend the basic "voltage stage + current buffer" topology of the 0147 headphone amplifier out to 40 wpc territory, you end up with the 0347.
The high power means that unlike the headphone amp design you have to run it out of class A, and that means closed loop operation.
While most people might be tempted to wrap the voltage feedback around the whole shebang, this basically ends you up with a big op amp. Op amps, with their massive negative feedback design, are not so happy driving high inductance/capacitance loads like speakers.
The trick 47 labs uses is to have two feedback pathways, with heavy "local" feedback around the op amp and a small secondary global loop from...
ID:	530   Click image for larger version
ID:	531   Click image for larger version
ID:	532   Click image for larger version
rjm's Avatar
rjm
Views 2434 Comments 2 rjm is offline
Old
Other options for a headphone amplifier.
Posted 15th December 2011 at 02:02 PM by rjm (RJM Audio Blog)
Updated 15th December 2011 at 02:08 PM by rjm
While I wait for the guys at 47 labs to get the Treasure 0247 together, I took a look around at some of the alternatives.
The Yulong D100 looks quite attractive and for about 2/3 the price of the 0247 kit you get a fully assembled unit!
review at head-fi
Or if you can do without a DAC, HLLY audio has your standard "transistor buffered op amp" implementation in a no-frills case:
HLLY RMK-5
It's listed at $240 but for sale on eBay for only $99 right now.
Of course there are dozens, but I single those two out as being particularly deserving of "honorable mentions". I'm still set on the 0247 though.
ID:	528   Click image for larger version
rjm's Avatar
rjm
Views 1885 Comments 0 rjm is offline
Copyright ©1999-2017 diyAudio
