Go Back   Home > Forums > Blogs
Old
Matching Stuff
Posted 27th November 2011 at 12:24 AM by Michael Rothacher (Audiohobby.com)
The topic of JFET and MOSFET matching comes up often in the forums, so I thought I'd show you the jigs I use.
First up, is my trusty old JFET IDSS matcher.
There's a 9V battery inside, and the meter probes are conneted across a 10 Ohm resistor which is connected to the JFET drain. I included a polarity switch for convenience when testing P channel parts.
It's pretty easy to connect the microclips, count to five, and take a reading.
And here's what I use for the big stuff. This is my MOSFET Vgs matcher.
First, I install a sample part and let it warm up for about an hour. There's a thermistor hot-glued to the heat sink,...
Michael Rothacher's Avatar
Posted in Uncategorized
Views 1366 Comments 0 Michael Rothacher is offline
Old
new layout
Posted 25th November 2011 at 01:32 PM by jtktam (Newbie audio DIYer)
Views 603 Comments 0 jtktam is offline
Old
Ck2iii pics
Posted 25th November 2011 at 01:30 PM by jtktam (Newbie audio DIYer)
Views 1356 Comments 1 jtktam is offline
Old
a10 preamp
Posted 25th November 2011 at 01:27 PM by jtktam (Newbie audio DIYer)
Haven't had a chance to update last two months.. the a10 preamp was completed with a little help from my dad and is now integral part of my setup. I even put my Linn magik up for sale.. it's that good.
Last month I started to gather the parts for the objective2 headphone amp. I got about 50-100 units worth of PCB and parts. I will start to package them as kits and sell some assembled. It will be my first try at selling here.
Last two weeks I finish building and rebuilding my Ck2iii headphone amp. The initial build was with an outboard power supply and headphone amp. The cost was running a little high since I build it using momentary switch, etc..
Then I rebuild it two days back into a single enclosure with a switch at the IEC instead. Cut cost down a lot since I no longer have to deal with umbilical cord, etc
-joe
Views 861 Comments 0 jtktam is offline
Old
Recycled parts, this time, a ZX Spectrum!
Posted 22nd November 2011 at 03:51 PM by DrDyna
Re-purposed my HiVi M6A into these ZX Spectrums designed by Paul Carmody. They're a groovy little speaker with this crossover and the B&G Neo3 PDR which I am absolutely in love with now.
Click image for larger version
DrDyna's Avatar
Views 1887 Comments 0 DrDyna is offline
Old
RJM Audio, now on Google+
Posted 21st November 2011 at 12:06 PM by rjm (RJM Audio Blog)
I hate facebook but I'm willing to give Google+ a go. Now they have "product" pages as well as "people" pages, I have made a little port to RJM Audio.
RJM Audio Google+ page
rjm's Avatar
rjm
Views 831 Comments 0 rjm is offline
Old
The Von Neumann architecture is becoming the niche.
Posted 15th November 2011 at 03:50 AM by abraxalito
Updated 5th March 2012 at 03:51 AM by abraxalito
https://garysmitheda.com/paper/ARM-Techon-note.pdf
Its a single page review of ARM Techcon. At the end I think he means 'PC design' not 'PCB design' as he's written.
He says:
If Intel doesn’t do something soon this might not be much of a war.
He knows some guys at Intel read his analysis so I think he's sugaring the pill. Intel is rather like the hare in the old fable of the tortoise and the hare. The hare woke up and tried to catch up with the tortoise but it was too late. That's exactly where Intel is right now - they've become awake to the issue but they've missed the boat.
abraxalito's Avatar
Views 979 Comments 0 abraxalito is offline
Old
Field Coil Wild Burro
Posted 11th November 2011 at 08:33 PM by DougL
https://www.diyaudio.com/forums/wild-...eld-coils.html
I had hoped that this might happen some day.
I will be watching this
Views 1046 Comments 0 DougL is offline
Old
a text
Posted 30th October 2011 at 08:09 PM by tomtt
Updated 29th January 2012 at 06:29 AM by tomtt
The perception of the higher order annoyance may be biological or cultural,
as not all musical instruments are made the same.
- a diyaudio forum member
My only advantage as a reporter is that i am so physically small,
so temperamentally unobtrusive,
and so neurotically inarticulate that people tend to forget that my presence runs counter to their
best interest
- joan didion
i should be frustrated but i can't seem to stop thinking about beautiful things .
- john mayer
''Closest thing to dying that I know of,''
Ali
tomtt's Avatar
Views 1034 Comments 0 tomtt is offline
Old
rolling your own (an adventure in coil winding) part II
Posted 28th October 2011 at 08:13 AM by wintermute (Wintermutes Rantings)
OK so I've been a bit slack getting to the second instalment. I actually finished the last coil about three weeks ago and have made the crossovers.
Tip number 1. Wear Gloves!! After the first coil my fingers were killing me. I'd pulled back the skin on my fingertips so hard that it was coming away from under the fingernails. Ouch!!! The gloves I subsequently wore were just normal rubber dish washing gloves. These worked quite well because they allowed me to put tension on the wire (holding the spool) and I no longer got sore fingers
Tip number 2. If you can make the same value with different size formers, choose the one with the lesser turns per layer. My pancake coils were much easier to make than the taller ones.
I think that the reason for tip 2 is that the more turns per layer, the more chance that small kinks in the winding wire will add up to enough to make it hard to get the last turn on for any particular layer. The coils...
ID:	509   Click image for larger version
ID:	510   Click image for larger version
ID:	511   Click image for larger version
ID:	512   Click image for larger version
ID:	514   Click image for larger version
wintermute's Avatar
Posted in Speakers, misc
Views 4112 Comments 0 wintermute is offline
Copyright ©1999-2017 diyAudio
