Go Back   Home > Forums > Blogs
Old
Quick identification capacitors
Posted 12th April 2011 at 11:53 PM by ferynov
quick drawing for identify original capacitors :
to my other blog
ferynov's Avatar
Posted in Uncategorized
Views 1804 Comments 2 ferynov is offline
Old
SSHV-Shunt Module
Posted 7th April 2011 at 01:19 PM by dvb projekt
Updated 30th November 2016 at 10:31 AM by dvb projekt (Stock status updated)
My last thoughts to optimize the Tube-I-zator goes to the B+ High Voltage lines.
To get the maximum flexibility, i have made splitting points in the lines.
The splitting of the anode psu lines brings upgrades possibilities.
You could use e.g. a tube rectifier with C-R-C filter instead of the onboard andoe psu or
switch to a regulated shunt psu, witch in my mind brings the greater sound quality upgrade.
With the experiences from Salas low voltage shunt on my DAC project in mind,
i have made an upgrade module for the Tube-I-zator based on his HV shunt circuit design.
Here it is
The specifications are:
- 2mm
dvb projekt's Avatar
Views 4348 Comments 0 dvb projekt is offline
Old
Tube-I-zator V2.0 Output Stage - Out of production
Posted 7th April 2011 at 01:14 PM by dvb projekt
Updated 30th November 2016 at 10:33 AM by dvb projekt
The Tube-I-zator V2.0
The evolution brings the following changes:
- Heater Switch without any relays
- Low ESR Heater PSU (e.g. Panasonic FM)
- Star Grounding
- Mounting holes for the HV-Salas Shunt Module
- Compacter design
The PCB has the following data:
Material: FR4 - 2mm
Layers: 2
Board size: 193x157 mm
Surface finish: Immersion Gold
Copper weight: 70µm
Soldermask: Both sides - green
Silkscreen: Legend on top
Out of production
Views 3985 Comments 0 dvb projekt is offline
Old
Rating: 2 votes, 5.00 average.
Reference TDA1541A DAC Power Modules
Posted 7th April 2011 at 01:01 PM by dvb projekt
Updated 12th January 2017 at 10:19 AM by dvb projekt (Stock status updated)
+/- Power Supply Module
- up to 15 caps per rail (16mm to 18mm diameter)
- place for decoupling foil cap in each rail
- place for bleeder resistor
- 105µm copper weight
- 2mm pcb
- Immersion Gold
- green soldermask on both side
- Board size 195mm x 120mm
Sold out
Shunt regulator modules
circuit design by Salas
- Shunt regulator module for TDA1541A (+5V, -5V, -15V)
- separate Shunt regulator module for additional parts (+5V)
- 70µm copper weight
- 2mm pcb
- Immersion Gold
- Board size 147mm x 115mm (46mm x 115mm; single +5V)
TDA1541A shunt module 2pcs. left in stock
Posted in Offer
Views 9106 Comments 0 dvb projekt is offline
Old
Low effort Class D with ready made modules
Posted 5th April 2011 at 04:45 PM by alexcp (My DIY projects)
Updated 6th April 2011 at 01:29 PM by alexcp
To try out Class D without working too much, I picked two ready-made Class D amplifier modules: one is the $45 2*100 Watt Class-D Audio Amplifier Board from Sure Electronics with the optional $10 volume control board, the other is the $199 IRAUDAMP7S from International Rectifier.
The Sure Electronics module is based on Tripath's TK2050 chipset. Powered from a 150W 24V SMPS from Mean Well, it predictably puts out about 22W RMS to a 8 ohm load. (The declared 2*100W requires a 30V supply and a 4 ohm load.) The sound and the measurements are decidedly mediocre, although at the $45 price, the module still may be a good value. Also, the volume control board feels odd, as the knob only adjusts volume after a push; another push disconnects it again.
The IRF module requires dual rail supply, for which I chose an SMPS400A180 by hypex. With +/-40V rails, the amplifier delivers 100W RMS into a 8 ohm load. The measurements are good, and the sound is very interesting for...
alexcp's Avatar
Views 1635 Comments 0 alexcp is offline
Old
I need Help im trying to build a leslie speaker
Posted 4th April 2011 at 10:58 AM by ZWade
im trying to build a leslie from mix and match parts so far ive got the speakers amps and crossover kits. im having trouble with what im going to do with the motors. does any one have any information on how to build alternative leslie speakers. i'm a beginner to build these types of things so the simpler the better.
Views 1034 Comments 0 ZWade is offline
Old
Emitter resistors and diamond buffers and distortion
Posted 3rd April 2011 at 03:36 PM by rjm (RJM Audio Blog)
Plenty of helpful advice in response to my question on emitter resistors, here.
And so finally I finish my prototype Sapphire amplifier, pictured below. The case is from Chinese audio outfit hlly, and very good. I bought it on eBay.
The rest of the components are described on my web page.
Click image for larger version
rjm's Avatar
rjm
Views 1955 Comments 0 rjm is offline
Old
Sapphire Headphone Amplifier
Posted 28th March 2011 at 02:15 PM by rjm (RJM Audio Blog)
Since I was effectively blogging my progress with the project as a forum thread anyway, perhaps it would be better to make it a blog rather than a post. I'm open to the idea, but does anyone ever read these blogs?
rjm's Avatar
rjm
Views 1225 Comments 1 rjm is offline
Old
For Paul
Posted 27th March 2011 at 03:18 PM by klewis
LME 49811 schematic is the one used for the tests with only the 30pf compensation in the circuit.
klewis's Avatar
Views 863 Comments 0 klewis is offline
Old
On distortion by Bob C
Posted 25th March 2011 at 08:30 PM by klewis
I don't find it hard to believe that very low levels of certain kinds of distortion are detectable when at the same time virtually un-measurable differences between passive elements like cables and capacitors are widely believed to be audible.
THD-20 does not tell the whole story on amplifier behavior, but it has also been given a bad rap because single-number usage of THD-20 can obscure the real story. If you have THD-20 with a full-spectral analysis out to the 7th or 9th harmonic, it tells a lot more, but most THD analyzers start cutting off at 80 kHz. One should always take note of the waveshape of the THD-20 distortion residual as well. If it is rather sinusoidal, that is often not too bad. If it is spikey, that is potentially very bad.
CCIF 19+20KHz with full spectral analysis is much better because the IM products lie in-band.
At the same time, moderate levels of benign THD, like mostly 2nd and 3rd, may not bother anyone very much. This...
klewis's Avatar
Views 712 Comments 0 klewis is offline
Copyright ©1999-2017 diyAudio
