Go Back   Home > Forums > Blogs > RJM Audio Blog
If I put my notes here, I might be able to find them again later!
Other Audio Things Audio items not directly related to RJM Audio projects.
Old
A different design aesthetic.
Posted 17th January 2012 at 11:52 AM by rjm (RJM Audio Blog)
Updated 25th January 2012 at 11:21 PM by rjm
I like the concept of appearance in high-end audio. I mean, where the look of the equipment makes a statement about what it's all about inside.
The 0347 is proportioned like a vintage tube receiver, but in miniature. It even has the lit, transparent front panel where the radio tuning strip would have resided. The heavy grey hammertone and very simple, basic hardware are reminiscent of Heathkit or Dynaco. In short, the appearance evokes the spirit of a simpler, more innocent age of vintage hifi without being a slavish replica.
Click image for larger version
rjm's Avatar
rjm
Views 1257 Comments 0 rjm is offline
Old
Another package in the mail...
Posted 14th January 2012 at 11:30 AM by rjm (RJM Audio Blog)
The 47 Labs "Treasure" stereo amplifier kit model 0367 has just arrived here at RJM Audio central command.
61,500 yen delivered, a tad more than the model 0247 headphone amplifier / DAC. Basically lose the volume control and DAC board, gain a bigger transformer and a thick aluminum bottom plate that serves as the heatsink... the amplifier circuit itself is almost identical, just with a slightly bulked-up output stage and the addition of certain safety considerations such as fine tune-able bias current and thermal protection for the output transistors.
Which makes an unusual circuit for a power amplifier: the output stage is a unity gain current buffer running open loop. For a headphone amp that's justafiable because the bias current is such that the amp will almost always be running in class A. For a power amp rated 40 W into 4 ohms, it's class AB.
Mr. Tsukahara seems pretty pleased with the result though, and I am anxious to try it...
rjm's Avatar
rjm
Views 1484 Comments 0 rjm is offline
Old
This vs. that.
Posted 13th January 2012 at 12:41 AM by rjm (RJM Audio Blog)
Updated 26th January 2012 at 06:42 AM by rjm
47 Labs 0247 vs. RJM Audio Sapphire
I wasn't even aware that the folks at 47 Labs were developing a headphone amplifier until after the Sapphire was finished, and I'm sure they didn't know what I was working on, so it's all the more remarkable just how similar the two designs are. Two separate answers from two separate people sharing the same general design philosophy.
Similarities:
- Solid state op amp voltage stage front end and solid state push-pull buffer running open loop for the output stage.
- Gain of 5-6x (14-16 dB)
- 20-30 mA bias current in the output stage.
- All BJT circuit** (see footnote)
- Use of "diamond buffer" circuit element. (Albeit in very different ways)
- 10 V voltage rails, split supply.
Differences:
- My voltage stage is an OPA134, or any 8 pin DIP op amp IC. 47 Labs voltage stage is a fully discrete current feedback op amp with a diamond buffer...
rjm's Avatar
rjm
Views 1224 Comments 1 rjm is offline
Old
47 labs 0247 : done, tested, working
Posted 12th January 2012 at 01:18 PM by rjm (RJM Audio Blog)
A few bumps along the way:
1. Soldered one of the caps in backwards. Removed and fixed, fortunately before power was applied to the board.
2. Soldered one of the transistors into the wrong place. Removed and fixed.
3. Dead channel on power up. Bad solder joint on the emitter of one the output transistors. Eyesight not what it used to be. Found on second inspection, fixed.
4. DAC board not level with cutout on front panel, had to use washers to raise it to the correct height.
Other than that, things went smoothly enough, though I spent more time with tweezers routing lead wires than is ideal for a commercially released audio kit. It's not so much difficult as it is painstaking - and I have quite a lot of experience doing these things so I imagine I had an easier time of it on the whole than most will.
The final result however is aesthetically quite pleasing, well worth the effort and expense. It is...
ID:	565   Click image for larger version
rjm's Avatar
rjm
Views 1700 Comments 1 rjm is offline
Old
Progress so far
Posted 6th January 2012 at 01:02 PM by rjm (RJM Audio Blog)
Updated 7th January 2012 at 03:00 AM by rjm
The first stage is getting the power supply installed and running. That's the little board by the transformer, which just has the diodes, main filter capacitors, and isolation resistors on the voltage rails. The case top lid is transparent plexiglass, so the internals are lit by three white LEDs to show off, and light the control labels, which are printed on the top lid rather than the front and back sides of the case.
You'll notice I have followed the instructions and removed the plastic covers on the electrolytic capacitors.
For the record I do think they sound better that way, I just normally can't be bothered as, for example, my phonoclone 3 boards have 28 of them and I consider the exposed metal surfaces a bit of a safety issue as well.
rjm's Avatar
rjm
Views 968 Comments 2 rjm is offline
Old
47 Labs 0247 unboxing, part deux
Posted 5th January 2012 at 11:29 AM by rjm (RJM Audio Blog)
My kit was missing the amplifier circuit boards! So many other neat stuff distracted me from this vital fact!
So far I've wired the AC power line components, transformer, and the power supply board. It's slow progress, mainly for wanting to be sure of getting it right the first time. It's dense and fiddly, desoldering stuff in there to fix a ****-up would not be pleasant work at all.
rjm's Avatar
rjm
Views 861 Comments 0 rjm is offline
Old
47 Labs 0247 "Treasure" unboxing
Posted 21st December 2011 at 04:33 AM by rjm (RJM Audio Blog)
Updated 22nd December 2011 at 10:47 PM by rjm
It's here!
It came in a box the size of a small shoe box.
Curious, delightful mix of the mundane and the exotic, outwardly plain but clearly immense thought and effort has gone into the preparation.
The gorgeous hammertone finish, hand-matched transistors, and ultra-high quality machined volume/selector knobs are the little signs that immediately set it apart from the ordinary.
ID:	548   Click image for larger version
ID:	549   Click image for larger version
ID:	550   Click image for larger version
ID:	551   Click image for larger version
ID:	553   Click image for larger version
ID:	554   Click image for larger version
rjm's Avatar
rjm
Views 2491 Comments 1 rjm is offline
Old
47 Labs "Treasure" 0247 shipping update
Posted 20th December 2011 at 12:19 AM by rjm (RJM Audio Blog)
Scheduled to be delivered tomorrow evening!
rjm's Avatar
rjm
Views 1331 Comments 0 rjm is offline
Old
Fascinating: SMT attenuator retrofitted into ALPs case
Posted 17th December 2011 at 03:08 AM by rjm (RJM Audio Blog)
https://www.icl.co.jp/audio/att.htm
Less than 3,000 yen, too. Pity it's only available as 100K types, but for tube amps this is a pretty handy little part to have around.
ID:	540   Click image for larger version
ID:	541   Click image for larger version
ID:	542   Click image for larger version
rjm's Avatar
rjm
Views 5577 Comments 3 rjm is offline
Old
47 Labs 0647 "Treasure" CD player diy kit
Posted 17th December 2011 at 02:54 AM by rjm (RJM Audio Blog)
Updated 17th December 2011 at 03:01 AM by rjm
Fancy building your own CD player with built in non-oversampling DA converter from a kit?
Look no further.
Based on a TEAC transport and ye olde Philips TDA1543 for the nonoversampling DAC
DAC is basically the Progression DAC (see DAC of ther Klones) reborn.
or salient details:
-top loading, close to the lit to automatically load the TOC.
- isolated digital and analog power supplies
- ATMEL AVR microcontroller, custom program/operating system
- simple, easy to understand display and controls
- standalone or use as a transport with external DAC
- small footprint, B5 size(W250 × H65 × D175mm)
- comes with a remote!
Although offered as a kit or pre-built, my suspicion is that all the real work has already been done: programming the microcontroller, now that's an area where most DIYers still fear to tread!
Not too many kit/home build CD players...
ID:	536   Click image for larger version
ID:	537   Click image for larger version
ID:	538   Click image for larger version
rjm's Avatar
rjm
Views 7768 Comments 4 rjm is offline
Copyright ©1999-2017 diyAudio
