Aleph J illustrated build guide
What are the key parts for Aleph J that are worth upgrading beyond the standard BOM?
Concentrate on R1, R2, R3, R4 and R24 and associated caps in the direct signal path?
I’m thinking of using s/z-foils - to try and inject some additional openness and move even more towards the speed/fire of tube amps if that is a plausible aim.
Dale resistors are cheap and sound good, but my tinkering heart says you could always try fancy components... whether it sounds superior will require some A-B comparisons. Not so easy with soldered components like resistors. You should also consider replacing R9, R10, R11, and R12.
I always advocate upgrading signal Caps. Film caps, where feasible, with copper film bypasses are my go to.
Reactions: stretchneck
ZM, after researching a bit, I understand the difficulty of explaining issues with my previous idea... Too many things wrong with the whole idea. So following previous solutions and Papa Pass's Sage advice... I inverted the whole thing with the intent of using IRFP9240 outputs. One thing I was confused on is whether inverting C2 and C3 polarity is correct (Not an issue with film caps, but I want it to look correct).
I noticed the symbol for the IRFP9240 was messed up, so I fixed that, and I removed the polarity for the negative feedback path after reading that some people use bipolar caps there with no issues.
Hello everyone! I've been struggling with one channel on my Aleph J build.
I must have messed something up in the initial testing, and now I can only get 7.85v at R8 and 0v at R18.
I did manage to toast a few of the 0.47 resistors by turning the potentiometers, but I changed them all out and also got a new jfet+mosfet kit from the diyaudiostore, just in case they got burned too. Desoldered and measured components again, reset the potentiometers. Still 7.85v at R8.
I can't figure out what's wrong. Any suggestions? Thanks!
Thank you for your quick reply, Anand!
I have a working power supply, thankfully. I used the schematic from the first post in this thread and followed this build guide: https://diyalephj.blogspot.com/
My boards look a mess from all the desoldering and resoldering, but here they are.
Check the attached; I removed the jumpers and R7 & R8' from the schematics to avoid confusion .... Read the instructions in the bottom right corner. Post the measured voltages.
If R18 reads zero, you don't have 4V across R7 (and/or the Q5 is not conducting)
  • make sure your R7 trim pot is working correctly and soldered properly; and that it makes contact with the PCB. Check and confirm that R8 is 1K and that it makes contact with the PCB
  • If R18 is still zero, the JFETs are most likely bad because there's no current through R8, so replace the JFETs.
  • confirm Q2 is the correct part, soldered the correct way
But... the bottom line is:
The best way to go about this problem is to take the measurements first, as per my instructions in the jpg I attached.... before you start replacing the expensive JFETs/MOSFETs. Post the results here and we'll have a look.
After R1,R2,R3, R4 & R27, the most important seem to be: R9-R12 at the output stage, with R16-19 before/after the mosfet.
R16-19 are 3W resistors, by what I can see most ‘audiophile’ resistors including AudioNote only go upto 2w and I don’t want to consider multiple resistors. Mundorf M-Resist Ultra MREU30 30W Film Resistors are available in .47R and they are rated to 3W in free air. Worth considering?
