Taping the holes will raise the area around the hole. Over tightening the bolts will do the same thing. I use a file to level the surface. Sandpaper with a flat board will work as well just slower. If you show no short it is not the problem of smoke but not being flat could make one of the mosfets run too hot by not being seated to the heatsink.
Do as Zen Mod stated first and go from there. If everything is installed correctly including the voltage wires it sounds like a wrong value something somewhere. Not a lot of components so you should be able to find the problem.
I think you may be right couple of mosfets looks like burnt because of no proper mounting on the heat sinks because of the mounting holes. I removed the board from the heat sinks and checked for all the components but looks like the mosfets have gone.
Your soldering look pretty good!so that's good...
Can you post a picture of the mounting holes... looking strange!
Thank you.
Do you mean the heat sink mounting holes?
Thank you.
Yes
I haven't got the time to do the diode test but did a ohm test and it looks like some resistance between the legs is present and its fairly similar with other mosfets as well for the same legs. I hope the mosfets are not conked
. Drilled and tapped a new set of holes on the heat sinks for the mosfets and refitted and did the test again but still the DC voltage on the output is 17.3V.
I hope this isn't too much to ask, but can someone explain to me or P.M. me the rundown of what's happening in the aleph schematic? I'm a little green on reading solid state schematics and I'm finding it difficult to understand what is going on within the aleph. Perhaps I'm just not familiar with the type of topology.This will be my first solid state build but I don't like to build things I don't understand.
You should start at FIRST WATT. In the Articles section you will find the "Zen Variations 2" project which contains a detailed explanation of the Aleph Current Source.
What's the point of the 220uf feedback capacitor C3 and R24? I can't see why it would need to block DC or why it would need to create an RC filter. It simulates the same without C3 and R24 as long as the current sense resistors are set for 50% AC current distribution. What am I missing?
easypeasy
(to understand ....... but not invent
Patent US5710522 - Amplifier having an active current source
use PAT2PDF - Free PDF copies of patents: Download and print! to down pdf ....... at least one enjoyable evening is in front of you ......
edit : in case you have few months time available , take a look at this : http://tinyurl.com/znw887r
![rolllaugh :rofl: :rofl:](https://files.diyaudio.com/forums/images/smilies/rolllaugh.gif)
too many variables (speaker/room combinations) possible , combined with too many pairs of ears
however , constructor/manufacturer needs to make his own choices ..... by memory , that ratio isn't fixed/same in all Aleph amps
in any case , so called Aleph AC gain isn't highest thing on the list , when one tries to grasp entire shebang
Works if you right click the link into new tab. AJ_Sch - My Photo Gallery
- Aleph J illustrated build guide
