Looking at the picture it seems there is now provision to use pins (just before the ufl connectors). But you cannot do a real direct connection (i.e. without wires).You mention that it direct connects to the S03. Can you explain or show a pic? Is there a header connection that eliminates the need for ufL?
The plan is to interface the S03 to any transport and DAC without having to roll out adapter boards for just about every interface and connect in some sort of articulated way.
In fact there would have been no adapter board for BBB like the BBB-DSD if the I2S/DSD switching were done internally within the BBB hardware/software and of course this risk of possible damage to BBB when power is interrupted, requiring additional arrangements as you can see on the board with the uC watchdog/battery
e.g other hardware like Amanero, WaveIO, etc do not require interface boards and can be wired-in directly. So, actually, this was what I meant by direct connections, typical DIY setup![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Acko, is the new BBB adapter board on offer/price, fully assembled?
Yes, assembled and tested as shown in the pic
Amanero with Najda DSP
I am not an expert in digital technics. I therefore have a question to the specialists here: I am using the Amanero connected to a Najda DSP From WAF Audio. I would like to insert an isolator, but still don't know what would be the best to do and how connect it. I have read most of the postings here and got a little confused.
Help will be much appreciated
Cheers
Sigi
Cheers
Sigi
Cheers
Sigi
Hi Sigi,
Although the basic concepts can be applied to the Nadja DSP a more specialized arrangement is needed to bring out the best - a little beyond the scope of this project. Please contact me for further information.
Looking good Acko.
Are you still needing me to test the DSD switching function?
Ray
All good to go actually based on bench tests. Will start shipping the orders by this Friday.
OK, I was hanging on in case you sent me a prototype to test but if all is good I'll get an order placed via your website.
Cheers
Ray
Great, that is good news!All good to go actually based on bench tests. Will start shipping the orders by this Friday.
Acko was kind enough to supply a file that allowed me to create a solder paste stencil to reflow my own S03 board. I built an arduino controlled reflow oven for another project and I try to use it when I can just because. Worked awesome for the S03! No flux to clean up and perfect joints at the push of a button. I misplaced a couple of potato chips and ufl connectors in my storage area, so I will need to do a little hand soldering after all.
BK
BK
Looks good. How did you create the stencil ?
Stencil is laser scribed into polyimide by OSH Stencils for small change!
This is the result of the solder paste application - the grey is the paste over the gold pads:
And this shows the stencil alongside the reflowed board:
Very neat. Found a similar supplier in the UK Welcome to smtstencil.co.uk
BK
Very impressive! Didn't think that a DIY solution will produce such professional looking results similar to that done on equipment costing thousands of dollars. Well done and thanks for sharing
![cheers :cheers: :cheers:](https://files.diyaudio.com/forums/images/smilies/cheers.gif)
Boxed with battery
The postie has just delivered a BBB/SO3 interface board!
All being well I'll have time to install and test it tomorrow.
Thanks Acko.
Ray
Today I installed into my DAC the BBB/SO3 interface board that arrived from Acko yesterday. I installed the interface board vertically on the BBB header to keep connections short; connections to the SO3 are via 10cm ufl cables. A picture is below.
It worked first time (so far). I've played PCM music so far. Reassuringly, the little green LED on the board lights up when I play 48KHz family data and is unlit with 44.1KHz family data; it implies the sample rates are being correctly identified so the correct clock on the SO2 is being used.
You can see I've wired up a momentary action switch and this has worked perfectly at shutting down the BBB.
Initially I hooked up the LiPo battery but uncovered an undesirable consequence; with the battery installed and, presumably, needing a good charge there was a significantly higher current load on the linear regulator I use to power the BBB and that was causing the R in the CRC filter of the supply to get very hot. Without the battery (but including the interface board) I measured a load of just under 400mA but with the battery it was almost 800mA. I believe the load will drop considerably when the battery charging switches to trickle charging but I decided to remove the battery and charge it separately then reinstall when fully charged.
The next thing to test will be DSD playback but first I have to check the required configuration and make any necessary edits to the Botic config files. I did try a DSD file but the DSD led didn't light up so presumably it wasn't correctly identified/processed.
BTW, an update to the Botic distro to V4 is now available;
http://www.diyaudio.com/forums/twisted-pear/258254-support-botic-linux-driver-71.html#post4309092
Anyway, here's the picture and I'll post another update when I have something to report.
Ray
Ray
Thanks for the report!
DSD led did light up when I tested with the sample file that came with Botic/ympd. Please check again.
Today I installed into my DAC the BBB/SO3 interface board ....
You should get similar action if mains power is lost (with battery connected)You can see I've wired up a momentary action switch and this has worked perfectly at shutting down the BBB.
Cannot avoid this as this is how battery charge requirements are. The load current will drop below 300mA when fully charged but even then the next time you power up the charge current goes up momentarily to 800mA before dropping back. PSU capacity needs to match accordingly.Initially I hooked up the LiPo battery but uncovered an undesirable consequence; with the battery installed and, presumably, needing a good charge there was a significantly higher current load on the linear regulator I use to power the BBB and that was causing the R in the CRC filter of the supply to get very hot. Without the battery (but including the interface board) I measured a load of just under 400mA but with the battery it was almost 800mA. I believe the load will drop considerably when the battery charging switches to trickle charging but I decided to remove the battery and charge it separately then reinstall when fully charged.
- Group Buys
- Amanero Isolator/Reclocker GB
