rossl said:You are correct and it cetrtainly isn't worth worrying about. There are no square waves in music.
Don't you remember the 80's synth thing?
yeah - but as point of interest "Oxygen" by jean michel jarre
100% synthesizer - sounds truly excellent
dunno how many waves are square but I get the feeling I am begining to hear it how he intended.
B.T.W. steep filter sounds way better than gentle filter
I cannot believe how good this sounds and I'm still in voltage mode !
and volumite is working nicely - thx![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
compuryan said:Will the sound quality be degraded any with the volumite attached vs. run passively w/o volumite?
I just added volumite and it sounds just fine, both at full volume and reduced a little bit - I also was wondering about this but my at least according to my ears it sounds good.
Of course as you turn it down the signal to noise ratio will get worse but perhaps with buffalo there is some leeway in this regard.
The amp I am using presently has a voltage gain of 21 so I need the volume turned down quite a bit so for now I am still using an analogue control but my next amp will have a gain off 11 and then perhaps I can use volumite only.
mike
BrianDonegan said:Can you hear the S/N ratio getting worse?
No, that was a rational observation, it sounds just fine.
Some purists don't like the idea of manipulating the bits but I never noticed that this causes a problem.
mikelm said:mmm - I was just thinking, perhaps volumite reduces digital noise as well as the digital signal - if that is the case then it's a pretty neat arrangement.
There is a very interesting white paper written by Daniel Weiss (Medea and Minerva DAC):
http://www.weiss-highend.ch/minerva/index.html
open the pdf "white paper".
For every 6db volume reduction you loose 1 bit. This is math:
If you shift a decimal number to the right, it will be divided by ten, you loose one digit.
If you shift a dual number to the right, it will be divided by two (-6db), you loose one digit(=bit).
If you play a 16bit file with the old buffalo, you can turn the volume down to
(24-16)*6 = 48db without loss.
I don't know if these rules are applicable for modern converters as well, because sometimes they internally work with an even higher bit rate.
regards
Andre
I'm trying to help a friend realise a John Swenson IV stage (based on Gary Pimm's CCS) for the output stage from a Buffalo Sabre Dac. He has an IVY & Counterpoint & I recommended that this IV stage might make a good comparison.
I'm OK with the JS IV stage as he has given lots of detailed info on it's workings & paramters (schematic attached). Will not be using the follower stage.
I'm looking for help with the following questions:
1.The current output of the buffalo is a high16mA, I think - if operating in SE output is this reduced to 8mA?
2. Is 221R the IV resistor used in the IVY & the buffalo?
3. What's the best way of getting SE output from the Buffalo?
4. Have people experimented with different quality IV resistors?
Any & all help appreciated!
Rolls, I'm interested in your experience with the trafo IV stage you're using - any advice?
jkeny said:Rolls, I'm interested in your experience with the trafo IV stage you're using - any advice? [/B]
Hello Ikeni
probably you read my post 1753.
I have used S&B with silver winding and a prototype Audio Consulting with copper wire, both wired 1:10. I/V resistor is, must be(!!) Vishay bulk metal, 1k or 2.5k, depends on the output you need.
After burn in Audio Consulting transformer is the clear winner, S&B is grainier. I have not tried Lundahl microphone transformers 1:11.2, which could be a good choice for less money.
regards Andre
Digital volume won't attenuate the inherent noise/distortion of the DAC, so it may be worthwhile configuring the analog gain of ones system to be no higher than it needs to be in order to maximize DR.
Having said that, I've found that digital volume control can give very good results.
jkeny said:I'm trying to help a friend realise a John Swenson IV stage (based on Gary Pimm's CCS) for the output stage from a Buffalo Sabre Dac. He has an IVY & Counterpoint & I recommended that this IV stage might make a good comparison.
Hi Jkenny,
1) Yes it is high, sure you can run it SE, but you will loose a lot of DNR.
2) No. Its 187R. OR 357. But really you choose the value based on the output you desire.
3) The old fashioned way. Just take one output and GND. But you will need to deal with the AVCC/2 offset not matter what you do.
4) not touching this one.
Cheers!
Russ
Re: AC1 with Buffalo32S and MUX working!
Hi Russ, when would this AC1/Femto ready for order? I want to have a Volume control, Femto seems promising to me, just wondering if I should wait it out, or get a Volumite first. Thanks!
Russ White said:Today I have been busy writing firmware for AC1/Femto that controls the Buffalo32S and Mux with these features.
Volume (RE and IR)
L/R balance (IR)
Mute (IR)
SRC selection (IR)
The display is VFD.
It is working perfectly.
I will probably also allow setting of certain registers. But I am not sure which or how yet.
Cheers!
Russ
Javin5 said:Not sure I really understand what you mean. I'm assuming you tested a prototype board and I'm also assuming all boards of the first batch will be fully tested prior to shipment?Kurt
The pcb design was untested when the boards arrived then after they assembled & tested one - then the design was tested.
Russ - I have a question about buffalo 1 cct diagram which I have just been studying before I connect counterpoint etc.
I can't help noticing that VA does not go anywhere except to 2 capacitors.
I was hoping you could explain what VA does in this cct.
does it provide the power for IC3 ?
thanks
mike
thanks
mike
VA is the analog power supply. It's sole duty is to power the dual opamp that acts as the AVCC voltage regulator.mikelm said:Russ - I have a question about buffalo 1 cct diagram which I have just been studying before I connect counterpoint etc.
thanks
mike
Cheers!
Rus
- More Vendors...
- Twisted Pear
- Buffalo DAC (ESS Sabre 9008)
