I have a pair of Vfets that I sourced from a generous member here and I’m a little confused as to whether they are the N-Type or P-Type.
Can a kind forum member explain briefly in layman’s terms as how I can identify which type of Vfet (data sheet needed?) I have or am I confusing the pertinence and relevance of what N-Type or P-Type as it relates to the actual build and it’s more of a engineering preference that the Vfets can be easily adapted too within the design parameters offered by Mr. Pass.
What part numbers are they ?Hi,
Sony 2SJ28 Kf-33What part numbers are they ?
Will there be an article (with schematic) when the PCBs are available at the store?Pcb's have arrived, and kit organizing will commence. 300 channels - 150 P and 150 N for the store.
Yes, in advance.Will there be an article (with schematic) when the PCBs are available at the store?
A new low cost, Toshiba-less, Linear Systems-less, front end card design is also ready. I will post the Gerbers on this site, one or two days after those 300 channels are in the Store. Then anyone can order front end boards from a fab and have them shipped directly to their home. (Also don't forget about the other front end Gerbers that are already on this site, for Scourge, Bulwark, Marauder, and Dreadnought).
- DIY SONY VFETS pt 3 - Got VFETs?
