Hi shlomid
We talk about the DC ballast is the first DC ballast,so I get a DC lamp at that time,and so I can take pic of DC lamp and I can show the pic in here.the first DC ballast is a DIYballast! rough!
life of the DC lamp = life of the AC lamp.
Hi sabrex
one 400w AC lamp+shipping=40$+5$.
set 40$+5$ up with 18wheeler.
Hi sabrex
Re: how to order thru 18wheeler
send me an email: DIYproj (AT) gmail (DOT) com.
I am sure I received paypal from manila last time. but I don't know how did he get it.
rmpmla said:18wheeler,
please PM how to order/make payment for YWH's lamp.
i would like to order 2pcs. 120wUHP 100AC lamp. YWH has the lamp.
have no paypal here in the Philippines![]()
thanks in advance
I requested a spec sheet directly from the lamp manufacuer. It turns out to be another company ( not the same manufaturer that ywh got his first ballast set from).
if you have access to the spec sheet of your ballast you can compare it again numbers listed here to have a rough idea if it will work with the lamp.
Code:
Lamp Watts Operating Current Lumens Color L.C.L Effective Arc Bulb Diam Average
Type w Voltage V A lm Temp K Length mm D mm Life h
JYs120/D.C 120 75 1.5 7200 160000 7800 37 2.4 11 1000
JYs120/A.C 120 75 1.5 7200 160000 7800 37 2.4 11 1000
JYs150/D.C 150 75 2 9000 190000 7500 39 2.5 12 1000
JYs150/A.C 150 75 2 9000 190000 7500 37 2.5 12 1000
JYs180/D.C 180 75 2.3 11000 180000 7600 40 2.6 13 1000
JYs180/A.C 180 75 2.3 11000 180000 7600 37 2.6 13 1000
JYs200/D.C 200 75 2.6 12000 170000 7400 37 2.7 14 1000
JYs200/A.C 200 75 2.6 12000 170000 7400 40 2.7 14 1000
JYs250/D.C 250 60 4 15000 160000 7400 37 2.8 15 950
JYs250/A.C 250 60 4 15000 160000 7400 41 2.8 15 950
JYs280/D.C 280 60 4.5 16800 150000 7500 37 2.9 16 800
JYs280/A.C 280 60 4.5 16800 150000 7500 41 2.9 16 800
JYs350/D.C 350 60 5.8 21000 140000 7400 41 3.0 17 700
JYs400/D.C 400 50 8 23000 120000 7000 41 3.5 18 700
Edited fromat:
Code:
Lamp Type Watts Operating Current Lumens Color Light Ctr. Effective Arc Bulb Diam Average
w Voltage V A lm Temp K Length Length L mm D mm Life h
cezza said:Does anyone with YWH's ballast find that it squeels constantly! The high pitch sound is driving me nuts!
The colour temp. on the lamp though is fantastic. Now the colours look more realistic.
Yes, mine has a high pitch hum. So does my 150W eballast. My ballast is sitting on a shelf in the garage with wires going through the wall to my projector so I don't hear it.
I agree about the colour temp, it looks nice. I wonder what it will look like with a 250W ballast?
I got my 250W ballast today but it didn't agree with my lamp. The lamp turned a grey colour inside. It still works with the PMA161X but is not as bright as it was.
18wheeler said:Edited fromat:
Code:Lamp Type Watts Operating Current Lumens Color Light Ctr. Effective Arc Bulb Diam Average w Voltage V A lm Temp K Length Length L mm D mm Life h JYs120/D.C 120 75 1.5 7200 160000 7800 37 2.4 11 1000 JYs120/A.C 120 75 1.5 7200 160000 7800 37 2.4 11 1000 JYs150/D.C 150 75 2 9000 190000 7500 39 2.5 12 1000 JYs150/A.C 150 75 2 9000 190000 7500 37 2.5 12 1000 JYs180/D.C 180 75 2.3 11000 180000 7600 40 2.6 13 1000 JYs180/A.C 180 75 2.3 11000 180000 7600 37 2.6 13 1000 JYs200/D.C 200 75 2.6 12000 170000 7400 37 2.7 14 1000 JYs200/A.C 200 75 2.6 12000 170000 7400 40 2.7 14 1000 JYs250/D.C 250 60 4 15000 160000 7400 37 2.8 15 950 JYs250/A.C 250 60 4 15000 160000 7400 41 2.8 15 950 JYs280/D.C 280 60 4.5 16800 150000 7500 37 2.9 16 800 JYs280/A.C 280 60 4.5 16800 150000 7500 41 2.9 16 800 JYs350/D.C 350 60 5.8 21000 140000 7400 41 3.0 17 700 JYs400/D.C 400 50 8 23000 120000 7000 41 3.5 18 700
what is the column with the 160,000 numbers???
have no idea. in Chinese that column was labeled 'brightness' or something. might be candela?
Seems to go down with wattage so that doesn't make sense, OK I was just wondering if you knew.
Cant remember if it was YWH, or 18Wheeler, but someone mentioned that to increase the power of the eballast, you need to change a few resistors.
Can you please say which resistors, and what they must be changed to?
Is there any risk in damaging the eballast running at this higher power? Will it handle it? Im guessing it will turn off by itself, as it has happened to prime if it gets too hot, so obviously it would need some cooling running at the higher power output.
Its worth a shot, since we already have it...
slodki said:Can you please say which resistors, and what they must be changed to?
That is not PMA161X ,that is this eballast.
slodki said:Cant remember if it was YWH, or 18Wheeler, but someone mentioned that to increase the power of the eballast, you need to change a few resistors.
The ballast overheated at the 150W power setting, it may or may not be able to take 200W or 250W. The overheating of the coil could case damage, and there may or may not be over current protection built in.
I'm not saying that this will not work but I would suggest incrementally increasing the wattage by small steps to see how the ballast reacts to the increased loadings maybe 10-20W increases upto the 250W target. The semiconductors probably have some hard limits that will ruin the devices as they are stressed too much. While not a power supply expert I've had to debug a few power supplies, so if someone could draw up a schematic from the board interconnects and part numbers we could look into what this ballast could be modified to handle without modification. By replacing the weak elements I'm sure we could modify these ballasts to handle 250W. The capacitors , resistors and semiconductors are easy to identify, transformers and coils are ussually semi or fully custom and very difficult to identify so that would be the hardest part in doing modificatons.
crazy! stupid thing to try.
I just plugged in my 400W magnetic ballast with my greyed 250W lamp.
It lite up with no problems. I let it run for a few minutes. The light was quite yellow but very bright. The yellow may be from the previous damage by the 250W eb.
prime said:
I got my 250W ballast today but it didn't agree with my lamp. The lamp turned a grey colour inside. It still works with the PMA161X but is not as bright as it was.![]()
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- I got my new lamp. It is for commercial projection use. people use it to replace the
