@billyk I'm thinking of doing something very similar... pretty much exactly the same without the re-clocker board just the isolator. Do you think the Subbu v3 power supply can supply the Amanero as well as the Acko board or are you just going to use bus power from your cpu for the Amanero?
This is way off topic, but this is not a great idea.
The supplies for either side of the isolator must be independent for the isolator to function. The DAC + isolated side of the isolator chip can be from the same pre-regulator.
I use bus power for my Amanero with Acko's isolator/reclocker board (only isol, for now).
I've assembled my JG Filter, just need to find time to hook it up now!
WK,
Do you have any extras of these?. Since the Subbu V3 dac will be released first single ended and later balanced, I have elected to build both and I will need one more filter. In fact if you can offer it with parts I would buy it that way to simplify things.
Bill
Bill
Many thanks to WK for all the donkey work.
I think people do not realise how many hours these all consumed .....
Patrick
as do I, matching these little suckers is a complete pita. think of the painful act of matching larger devices and multiply x 5
- Group Buys
- Joachim Gerhard Filter Buffer for ES9022
