MikeBettinger said:
I would love to find these or a suggestion for an alternative. It seems impossible to build anything with with FETs these days.
Is there a source for the Toshiba's or any predictable alternative? Is Erno the only source? He doesn't appear to list the 389/109bl's anymore.
Regards, Mike.
What about those new LSK389-devices? Don't they qualify?
Or not to get?
Rüdiger
john curl said:Mike, what part of the USA do you live?
Hi John,
I live in Virginia.
Or not to get?
Rüdiger
There is no P-channel mate to it.
Mike
Yet.
I checked in with Linear Systems last spring and they were running test batches for the P-ch devices at that time. They were experiencing some sort of a yield problem (unspecified), but they're well aware of the pent-up demand for matched N & P-ch dual JFETs. They intend to meet it ASAP.
Grey
Grey
This sounds like a source of cheap, wide range charactistic FETs could be coming to market.GRollins said:Linear Systems ..............were experiencing some sort of a yield problem (unspecified), but they're well aware of the pent-up demand for matched N & P-ch dual JFETs. They intend to meet it ASAP.
john curl said:You can hand match 2sk170 and 2sj74 parts. This will work just as well, but you have to buy more than a minimum to get good matches.
Upupa Epops said:Guys, do you have some experiences with mosfets on input position ? With really modern types like zvn/zvp 3306 or 3310 ( or similar ), not with old irf 110 ?
I used to have a zvp3310 as a buffer input (30mA bias)...I replaced it with a 2sj74 (10mA) and never looked back. I didn't throw away the 3310...it was moved to cascode duty
john curl said:You can buy what you need at: The Company Store or Erno Borbely. The prices are reasonable for out of production parts.
Hi John,
I found the Company Store and they have the 2SK170BL and the 2SJ74BL. I have them on their way, although I'm not sure where they are located and the flat shipping charge doesn't bode well for having them for the weekend.
Thanks for the suggestion.
Regards, Mike.
Don't worry about the fets, just get the Idss close and everything will follow. How do you think that we made the first series, before complementary jfets were even available?
This jfet input stage tends to adjust out differences. Of course there can be some residual offset, but that is manually adjusted out in the original design, after warm up. There is no DC stage gain IN THE ORIGINAL DESIGN so it does not further amplifiy the input offset.
When enthusiastic 'fellow designers' modify and remove these initial considerations, then they get into trouble and start complaining. However, they do it to themselves, the circuit will take care of itself, if left in its original form, in spirit, at least.
This DC offset setting circuit (pot + 2 resistors + filter cap) was not any important for simulations, so replaced by battery and then omitted completely. Anyone can feel free to put it back. I assumed potential builders would think it over.
Anyway, the DC stability would not be great even with this circuit, that is why original design has input capacitor (wise), though it is against author's philosophy.
The 1O UF polypropylene, polystryene, polycarbonate cap was added 1/3 of a century ago, and we were only just learning about capacitors. I used polycarbonate coupling caps with the Levinson JC-2 preamp. Why would we NOT have a coupling cap in this amp?
Also, the very FIRST example of this design was used as a tweeter amp, so the coupling cap was much smaller, perhaps as small as .1 uF
Later designs, past 1977, I started to use servos, but this design did not, as it was made between 1974 to 1976.
Actually, with modern matched fet pairs, (like I would use) the cap really isn't necessary. It is just to keep amateur diyers from getting into trouble, like they are here, even in simulation.
I didn't make a big deal out of the offset compensation being left out of the SIMULATION. Only the 'hand-wringing' of the people who don't think that the amp will work with real world devices. The catch resistor is a good idea, why did you not recommend it from the first? Perhaps you did, and I missed it.
- John Curl amp
